Front crank dampener for a 8070
 Post Reply Post Reply Page  <1234>
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2023 at 7:25am
I have seen pictures of bad balancer cut open. The fluid was dried out looked like plastic sheet.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 12:57pm
Yes, loads of good info on this forum. Thanks to everyone for their contributions. This dampener thing is hugely important. Seems like there should be a mfg’s schedule for replacement of their engine’s dampener?? Did AC dealerships receive company bulletins about it? Or,,, possibly it’s a difficult item to forecast? Maybe some wear out faster than others because of different customers’ usage?
Edited by AC7060IL - 04 Feb 2023 at 9:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 2:54pm
When a rubber damper wears out or fails, it's obvious to see as the pulleys get crooked or they rub a hole in the timing cover. The viscous (fluid) dampers are certainly more difficult to diagnose and are recommended to be replaced by some engine manufacturers at OH time or certain hour intervals. A-C did not specify.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 9:04pm
We always did ours at 3,000 hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2023 at 2:18pm
If you can buy a 4-71 DDA version for $500 (appears to be the same) VS OEM for $1500  (got it discounted to $1400 2yrs ago) it would be money well spent especially around 5000 hrs.
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2023 at 5:50pm
I had been taught that a bad dampener could also result in a broken crankshaft.  There must also be some interesting industrial history here too (not that as Allis fans we are interested in industrial history).  Stahl dampeners were made by Carl Stahl who, according to his obit, worked for Cummins in IN and relocated to Memphis to start Cummins Recon.  Does not appear that Stahl became a major manufacturer or maybe he was bought out by someone else.  His obit states that he invented the Transdamper.  Wonder why he wasn't a major manufacturer with the widespread use of crank dampeners.
Edited by jeickman01 - 05 Feb 2023 at 5:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2023 at 8:48pm
According to Vibratech data the 4-71 damper is 10.8 Dia and weighs 14 lbs. I tape measured old Stahl at 10 7/8 Dia and it weighs 12.5 lbs. Close enough? If bolt pattern matches. Peterson has a 6-71 damper bolted on which is bigger but I'm betting the bolt pattern for the 71's are the same. A phone call could confirm bolt circle diameter. I think the Detroits were thicker rings thus the weight difference.
Edited by SteveM C/IL - 05 Feb 2023 at 8:50pm
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 6:51am
 https://www.vibratechtvd.com/detroit-diesel-replacement-dampers...
I also know an individual involved in that arena at an international level and am picking his brain.  He said that Mack's logic  "Use the biggest one you can find they will fit bolt pattern. Can't get one too big."  is generally a desirable consideration but unfortunately too often the damper is designed around the engine and not the reverse...So many are product specific unless one gets lucky...Good topic and I hope it gets moved to the knowledge section....Dale
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 9:26am
I suppose that it's been at least 25 years ago now, when I was working at the farm equipment dealership yet, I customer had the nose of the crank shaft break off on his 8070. Was such a pity to see the whole engine have to be torn down and new crank put in when it was running perfectly fine. After learning more, and after reading this thread, looking back, I'd bet anything that it was the result of a bad dampener. Had the customer had a tell tale sign or something, replacing the fluid dampener would have been a way cheaper fix.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 3:23pm
Agree Dale. That's why the BIG diesels have big dampers. when you take a given horsepower engine and crank it up,the OEM design balancer becomes inadequate for the new harmonics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 6:05pm
Maybe the AC Big Al 25000 844 didn’t have a big enough harmonic dampener? It was 425hp at factory. R&D had several trucks that they pushed more fuel to produce 900hp, before settling at 600hp on some. Big complaint with them was broken crankshaft at/or near #1 cylinder.
Edited by AC7060IL - 06 Feb 2023 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2023 at 6:26pm
There was a crankshaft nose improvement on the last year or two (1985-86 ?) of 426 engines that not many people are aware of. A bad damper can cause lots of problems for sure, but there was an apparent weakness in the 426 crankshafts that was addressed in these last couple of years of production. The engineers removed the two half-moon keys from the cranks nose area (one for the crank gear and the other for the crank pulley) and replaced them with small round pins. This reduced stresses that were there with material removed when they used half-moon keys. The other change was they went to a smaller diameter bolt to retain the crank pulley that was much longer and was threaded deep into the front main bearing journal, putting the nose of the crank under compression, making it stronger. These two changes were an improvement to reduce crank nose breakage. Big Al cranks needed that done to them. A truck engine crank goes thru a lot of twisting under full acceleration and load. Then, you get completely off the throttle to shift gears and then back down to the floor again. This constant twist and release is very hard on crankshafts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 6:06am
Did Allis use Viscous dampers later in life of company? What I am noting is those have a defined hours lifespan where the Viscous Gel hardens and the dampers become functionally useless. Cat Cummins and Detroit has service literature as to replacing these at specific engine life intervals.
I replaced the one on my Cat truck engine and cut the old one open, was as depicted with the gel almost to gorilla snot glue consistency not gelatinous.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 6:41am
From the very first 7080 engine on up (7580-8070-N5-N6-R5-R6-4W220) always had a viscous damper. All these engines also had the counterbalanced crankshaft and produced the most HP at the highest rated RPM's.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 8:21am
Can a rubber 7060 damper be used on the 7080 motors if motor is only going to see 2300-2400rpm and
If there is nothing else available?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 9:13am
Could be. Diameter of the pulleys the same??  Higher HP and higher RPM's is why they had to get away from rubber type.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 11:43am
If no one is making or rebuilding these dampers these engines will be grenade potentials within a few years.   This is not a IF, is a WHEN.  All technical manuals for diesel engines with Viscous Dampers notate these need to be rebuilt or replaced at intervals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 12:29pm
Hopefully, the one from a 4-71 Detroit will fit.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 2:46pm
Injpump Ed came up with a Dertiot#5177763 from a 3/71 4/71 6/71. If its not the same its mighty close to the Allis damper
Between all of us we will gind a solution
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
MikeKroupa View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeKroupa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2023 at 7:58pm
Very good and informative conversations here for sure, In reference to Darrel's and Doc's post concerning crankshaft nose breakage. We had a neighbor that purchased a new Series 3 N5 in 1983. Really got along good with the machine until the fall of 1988 when the nose of the crank broke clean off. Didn't tear anything up and he didn't realize it had happened until the coolant temperature light came on. Catastrophic failure none the less, but at least it was only the crankshaft., Mike
 I forgot to add that my 7080 has 9300 hrs. on original dampener, probably  won't run WOT until I change it out!
Edited by MikeKroupa - 07 Feb 2023 at 8:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2023 at 9:00pm
Darrel
****My thoughts were also along those lines...I have wondered if throwing that #1 rod is connected.  I have seen three of those and  one being in a R5 that I now have.  Rod came out the side of the block...Also a couple of cracked cranks at the front main..I hear that it is possible to put a damper in clutch plates and at the flywheel of setups like N series and such...And if I remember correctly, I think they were all just over that 3000 hr mark....Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2023 at 10:31pm
We have a 8050 that had cracked block. Bought a running 8070 motor from a junk yard. We might be swapping pumps out. Wondering after reading all this. Should we take fluid balancer off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2023 at 10:36pm
You either use it or replace it with new. Cannot operate without one. How good do you think a 40 yr old fluid damper is ??
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2023 at 8:33am
I'm making a mental note of this for future reference as my 8070FWA is still my big horse.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2023 at 9:58am
Just a reference.  When I replaced my CAT Damper there was no core so cut the old one open.
This is result.  Gel almost all glue like, nothing to flow, to move the internal ring Had to use a Pry Bar and Hammer in the Cut Groove.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2023 at 11:34am
IF you had a motor that was lucky to be closer in balance, would it make less of a difference then a motor that was farther out of balance? Or if the motor was being ran when the fluid in the balancer began to solidify verses a motor that sat for months without running and the balancer solidified and made it way out of balance?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2023 at 11:58am
It is not a "balancer" like adding weights to a car tire. It is a harmonics vibration damper. Harmonics at certain engine speeds and load like a guitar string vibrating. It tryies to cancel out these harmonics vibrations by the donut starting and stopping all while the outer shell rotates.  With the silicone fluid missing (leak) or solidifying (old age) the donut can't do its intended job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2023 at 2:04pm
Maybe someone can convince TCI to make their "Rattler" damper for our Allis applications. The cam gear on my C15 Cat has that design built in it.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2023 at 4:07pm
“IF you had a motor that was lucky to be closer in balance, would it make less of a difference than a motor that was farther out of balance?”
You can have Perfect balance, and you still need a harmonic balancer. The piston movements and combustion effects cause a slight back-and-forth twisting of crankshaft that causes large stress reversals and the harmonic balancer helps to cancel them out.
The flywheel end has a much larger mass so it pretty much is its own dampener.
More here:
https://www.dieselarmy.com/tech/engine/how-it-works-viscous-dampers-a-k-a-harmonic-balancers/
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2023 at 6:41pm
That is a very informative article on fluid filled dampers. A very good read. Thank you for posting.
