Free Power |
Coke
Topic: Free PowerPosted: 04 Jan 2021 at 3:22pm |
https://phys.org/news/2020-10-physicists-circuit-limitless-power-graphene.html
team of University of Arkansas physicists has successfully developed a circuit capable of capturing graphene's thermal motion and converting it into an electrical current. "An energy-harvesting circuit based on graphene could be incorporated into a chip to provide clean, limitless, low-voltage power for small devices or sensors," said Paul Thibado, professor of physics and lead researcher in the discovery. The findings, published in the journal Physical Review E, are proof of a theory the physicists developed at the U of A three years ago that freestanding graphene—a single layer of carbon atoms—ripples and buckles in a way that holds promise for energy harvesting. The idea of harvesting energy from graphene is controversial because it refutes physicist Richard Feynman's well-known assertion that the thermal motion of atoms, known as Brownian motion, cannot do work. Thibado's team found that at room temperature the thermal motion of graphene does in fact induce an alternating current (AC) in a circuit, an achievement thought to be impossible. In the 1950s, physicist Léon Brillouin published a landmark paper refuting the idea that adding a single diode, a one-way electrical gate, to a circuit is the solution to harvesting energy from Brownian motion. Knowing this, Thibado's group built their circuit with two diodes for converting AC into a direct current (DC). With the diodes in opposition allowing the current to flow both ways, they provide separate paths through the circuit, producing a pulsing DC current that performs work on a load resistor. Credit: University of Arkansas Additionally, they discovered that their design increased the amount of power delivered. "We also found that the on-off, switch-like behavior of the diodes actually amplifies the power delivered, rather than reducing it, as previously thought," said Thibado. "The rate of change in resistance provided by the diodes adds an extra factor to the power." The team used a relatively new field of physics to prove the diodes increased the circuit's power. "In proving this power enhancement, we drew from the emergent field of stochastic thermodynamics and extended the nearly century-old, celebrated theory of Nyquist," said coauthor Pradeep Kumar, associate professor of physics and coauthor. According to Kumar, the graphene and circuit share a symbiotic relationship. Though the thermal environment is performing work on the load resistor, the graphene and circuit are at the same temperature and heat does not flow between the two. That's an important distinction, said Thibado, because a temperature difference between the graphene and circuit, in a circuit producing power, would contradict the second law of thermodynamics. "This means that the second law of thermodynamics is not violated, nor is there any need to argue that 'Maxwell's Demon' is separating hot and cold electrons," Thibado said. The team also discovered that the relatively slow motion of graphene induces current in the circuit at low frequencies, which is important from a technological perspective because electronics function more efficiently at lower frequencies. "People may think that current flowing in a resistor causes it to heat up, but the Brownian current does not. In fact, if no current was flowing, the resistor would cool down," Thibado explained. "What we did was reroute the current in the circuit and transform it into something useful." The team's next objective is to determine if the DC current can be stored in a capacitor for later use, a goal that requires miniaturizing the circuit and patterning it on a silicon wafer, or chip. If millions of these tiny circuits could be built on a 1-millimeter by 1-millimeter chip, they could serve as a low-power battery replacement. |
1957 D17 Diesel w/ M&W Pistons
Joined: 11 Sep 2009 Location: illinois Points: 87819 |
Posted: 04 Jan 2021 at 4:20pm |
who said there is no such thing as Magic ?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24684 |
Posted: 04 Jan 2021 at 5:16pm |
re: ..."We also found that the on-off, switch-like behavior of the diodes actually amplifies the power delivered, poppycock..... re: ...which is important from a technological perspective because electronics function more efficiently at lower frequencies. so we're going to get rid of 5G phones and 5GHZ PCs for um, well Teletypes ? I think not... re: ...current flowing in a resistor causes it to heat up, but the Brownian current does not ANY current flowing through a resistor HAS to cause it to heat up as Power= I squared R law of physics.... re: could be incorporated into a chip to provide clean, limitless, low-voltage power for small devices or sensors, yup, here we go, again, a perpetual machine.... this time 'free' energy in the form of electrons....... sad thing is some people actually believe this drivel...... must be all demoncraps..... |
Posted: 04 Jan 2021 at 5:33pm |
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 05 Jan 2021 at 7:26pm |
poppycock? Doesn't a hydrogen bomb give off a lot of "free" energy? OH wait, maybe that's atomic energy.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 41980 |
Posted: 05 Jan 2021 at 8:03pm |
Yep if your at ground ZERO - you can get all the free energy you will ever want or need !
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12185 |
Posted: 06 Jan 2021 at 6:30am |
Not perpetually, just a LOT all at once!
jaybmiller
Posted: 06 Jan 2021 at 7:53am |
hay, if YOU'RE at ground zero, you'll have more than you'll ever need in your LIFETIME !! the really sad thing is sheeple actually BELIEVE this kind of KRAP...
HD6GTOM
Posted: 06 Jan 2021 at 6:28pm |
Don't tell the old gal about this. She'll have 1 or 2 hooked to me butt cheeks a wanting me to gwet busy and do sumptin.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 33967 |
Posted: 06 Jan 2021 at 7:31pm |
More Black Arts PFM BS. If really did this would be all over, can you spell SCAM!!!
