FPD50-24-2PS blow by? |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Topic: FPD50-24-2PS blow by?Posted: 06 Dec 2013 at 4:24pm |
OK, my Buda powered AC forklift has a fair amount of 'blowby' ...smoke coming out of the oil filler cap. Need opinions of what is causing it, what to do about it and the bottom line what's it going to cost ???
I have to start her up with ether unless she's warm....yeah, another 'problem'...but she's a valuable member of my A-C family!
jay
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 06 Dec 2013 at 8:28pm |
Do a compression test, likely a lot of blow-by from worn rings. New valve seals and guides might help, if that motor has 'em...
jaybmiller
Posted: 07 Dec 2013 at 6:53am |
hmm..forgot to mention she's a diesel....if that matters...
jay
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 08 Dec 2013 at 7:40am |
Is it a 4 cylinder or a 6 ??? One of them in a diesel is a rare bird.
Edited by Calvin Schmidt - 08 Dec 2013 at 7:40am |
jaybmiller
Posted: 08 Dec 2013 at 9:00am |
She's a diesel 4 cylinder.Ain't got a lot of driving power but will lift over 5000# without complaining!
'Rare', eh ! Sounds like someone might want to buy it ?
Problem is she's super handy around here, though a gas equal would be OK too.
Jay
jaybmiller
Posted: 08 Dec 2013 at 11:57am |
update...used two spray bombs of brake cleaner to get some of the black crud off the engine.Can't find an engine plate anywhere,but I was told it's a Buda.
4 cylinder diesel with one glowplug in the intake.
I'm wondering if it's a good/OK idea to plumb the blowby into the air cleaner ? It'd sure keep the engine a lot cleaner !
all ideas welcomed !
Jay
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 08 Dec 2013 at 10:50pm |
With the hard starting, I would bet it has weak compression - needs a rebuild. My 190 XT is the same way. Needs ether on the hottest day of the summer. A rebuilt would also clean up what is coming out of the vent pipe. Plumbing in vent tube into the air cleaner? I'm biting my tongue to what I really want to say about that! Some gaskets and tightening all the bolts (believe it or not!) on that engine would help keep it clean.
jaybmiller
Posted: 09 Dec 2013 at 6:55am |
aw..don't bite your tongue, speak to me !
My thinking was it'd be like PCV on every car/truck since the mid 60s ?
jay
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1009 |
Posted: 11 Dec 2013 at 9:28pm |
If the oil pressure is good you could really improve this engine with a new set of piston rings (the pistons may not be reusable).....and a gasket set....cost would be kept to a minimum. Re your question to plumb the blow-by to the intake I would say do it. I've done this to two 3204 Cat engines and it works perfectly fine. That blow-by smoke would make me sick to my stomach after a few hours of operation....but not any more.
jaybmiller
Posted: 12 Dec 2013 at 1:56pm |
Hay Eric
I'll replumb when it get a a tad warmer here in southern Ontario. -10*C = 10*F = COLD !!!!
In the meantime I'll call around to get a price on the 'ring thing'..sigh... gee Santa..what I want for Xmas is.....
cheers
Jay
