Four-cylinder in-line Ford
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: Four-cylinder in-line Ford
    Posted: 9 hours 22 minutes ago at 8:06pm
Have a four-cylinder in-line Ford in a Joy air compressor. It runs great for the man in town, but when I get it out here to the farm, it will not run. Can a coil be good and then bad and then good and then bad. I would think once they go bad they’re bad. This will be the third time in a week. I’ve taken it to him. The man who works on it is absolutely incredible. You may not doubt his abilities. He can rebuild your Briggs & Stratton or your CAT C 15 engines. I cannot allow you to doubt his work. We have just got an intermittent problem on this engine. Can a coil be good one second bad the next and then go back to being good?
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 9 hours 11 minutes ago at 8:17pm
I had an International 560 tractor that I could never start. Would have the mechanic come and that thing would start. Finally, after a couple times he says let's put an inline fuel filter that they sell at wal mart on this just to be safe. We put one of those in and I never had trouble getting it to run again.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 15 minutes ago at 9:13pm
Is there fuel in the tank and is the shut off turned on?   Thumbs Up
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 4 minutes ago at 2:24am
Things don't happen for no reason.  SOMETHING is changing.
Is the Ford an overhead valve industrial 134, 174 or 192?
