Found at the farm |
Post Reply |
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3445 |
Posted: 14 Aug 2019 at 1:36pm |
I thought this was kind of neat. I have walked under this thing for almost 50 years, couple of months ago I notice the marking on the bottom. Thought it kind of cool to have another piece of AC stuff. One I didn't even have to buy!
BrianC
Orange Level Joined: 16 Jun 2011 Location: New York Points: 1613 |
Still working I assume. So that is a 50 year paint job? Anyone know what kind of paint they used for electrical transformers?
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21464 |
maybe epoxy ?? I figure 2-3 hours and someone here will post the original specsheet for that transfomer along with test data........
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11549 |
A lot of the real early pots like that where painted with an oil base epoxy paint for weather resistance. I believe a lot of our transformers at work are powder coated now. That ole' bugger probably has PCB oil in it. If you see it leaking, better report it so the local power co. can change out the pot. I was just in one of our substations repairing a truck that broke down in the sub and glanced over to see a rectangular sign on one of the large units that said "Allis/Siemens". I thought... pretty cool.... Steve@B&B Mike- I just noticed your in Newton, IA. The power co plant I work in is in Newton, NJ.! LOL!
Edited by Steve in NJ - 14 Aug 2019 at 4:52pm |
JW in MO
Orange Level Joined: 16 Feb 2010 Location: South KC Area Points: 2595 |
Well get a load of this, I snapped this picture North of Newton KS. |
Tim NH
Orange Level Access Joined: 16 Oct 2012 Location: Lancaster NH Points: 1059 |
Mike I'm guessing the pole and transformer are close to 70 years old. I think your power company has got its monies worth. JW your picture if of a voltage regulator. I bet it works as good today as it did when they hung it 50 years ago. Tim
irlbeck A-C'S
Orange Level Joined: 28 Sep 2009 Location: Crestview FL. Points: 684 |
The pic JW posted is a Voltage regulator. It steps voltage up or down as load on the line increases or decreases.
On the cross arm above it there are 3 switches, source(in) load(out) and a bypass(one that is open in the middle) To bypass the regulator it MUST be stepped up or down into the neutral position. Meaning the voltage incoming is the same as voltage outgoing. If it is not in neutral when bypassed it will explode..... The round item just above and left of the AC symbol is a dial that you watch when you step the device up or down to zero. A light in the panel then comes on along with the dial being on N indicating neutral... Just a little useless info to pass along. I love seeing all the AC stuff still out there working today. It's good equipment.. |
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
There was a big AC transformer on the ground at the original AE Staley in Decatur IL.(now Tate & Lyle) Haven't been there for a few yrs but I imagine it's still there and working.
Lonn
Orange Level Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29773 |
Wink I am a Russian Bot |
wekracer
Orange Level Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1587 |
Sounds like quite a few of us work for power companies.
The substation transformers in Versailles Mo are AC. The turbines and generators at Bagnal dam Lake of the Ozarks are AC. There is a placard on the side of the turbine housing that says made be Allis charmers. 2500 HP at 112 RPM. If I remember correctly. I know it’s 112 RPM. May be off on hp. |
irlbeck A-C'S
How is this for a little AC horsepower... Just a little over 39,000 |
Gatz in NE
Orange Level Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1030 |
some big AC stuff... at about 4:15 Years ago, we were able to take a tour similar to the one in the video. After 9-11, those areas were off limits.
Tim NH
Craig are your control box's mounted to the reg like in that picture. Ours aren't, we don't want the line man fooling w/ it. lol Tim
IBWD MIke
There seems to be several Newton residents here. 2500 HP at 112 rpms, that is some serious torque!
SteveM C/IL
Take the 39000hp at 90rpm if you want to talk torque!!!
IBWD MIke
Missed that! How big of a shaft would it take to transmit that?
irlbeck A-C'S
It's been a while since I looked at those turbines. There were 3 AC turbines in the hydro plant. The shaft was feet in diameter but don't know how many.
Tim our regulators are mounted on a plaform between poles. A few on the pole itself. Most panels are mounted eye level when standing on the ground. Eye level for most. There are a couple of shortys in the workforce....lol I have worked on some regs that had a small can on the side. You unlatched it,turned the knob and watched balance beams line up to get it to neutral. That was some really old stuff. |
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5637 |
Mike said:
2500 HP at 112 rpms, that is some serious torque! - 117232 ft-lbs. Bagnal dam has eight generators with a maximum capacity of 215 megawatts... that's 288319hp... or 36,039hp per generator... so the turbine you're noting is clearly just a little auxiliary power turbine (for powering lighting and controls, not feeding the grid). Bagnal has 90ft of hydraulic head, that's 38psi... how fast do the 8 MAIN turbines spin? we can calculate a whole lot from that... Steve said: Take the 39000hp at 90rpm if you want to talk torque!!! -That's 2281702ft-lbs. At 49ft head, that means 21.2psi water pressure on 750 square feet of turbine surface area.
woodsman89
Bronze Level Joined: 17 Mar 2018 Location: iowa Points: 42 |
a few years ago on a tour of the cement plant in Mason City, Ia. I seen the bearings that the kiln rides on were AC. They're 3 feet in Diameter and the kiln at the time was a foot away from them because it was cold. When heated up and running it swells out to them.
If I remember right the main bearing of the Queen Mary prop. shaft is AC. |
IBWD MIke
Thanks Dave for the calculations, that is a LOT of torque!
wekracer
Dave I’m sure your right about Bagnal. I didn’t remember the hp but I can tell you with certainty that it was 112 rpm. I don’t know why I remember that and not the hp but I guess that’s the way it goes. It’s probably been 12 years since I was there. Edited by wekracer - 18 Aug 2019 at 10:45am |
frnkeore
Silver Level Joined: 07 May 2019 Location: Southern Oregon Points: 362 |
That is 2,282,000 ft/lb of torque Perfect for my D17!!! |
Frank
1959 D17 Series I #24001+, '59 D14 '55 & '59 Ford 850 & 861 Ferguson TO 35 Deluxe, Oliver 70 and 5 more. |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 7943 |
That business made Allis serious money back in the day , there was an Allis on ground transformer thing down in the bottom by Rich Fountain , last year they brought an 80 ton crane in and special under slung trailer to load it and haul it out,, must have been a heavy rascal
Post Reply | |
