Found a D 15 series 2
jeffrey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffrey Quote  Post ReplyReply Direct Link To This Post Topic: Found a D 15 series 2
    Posted: 06 Mar 2010 at 6:03pm
Found a real nice D15 series 2. Three point hitch, gas , 1450 hours(on working tach) Stays in gear. Guy wants 3500 for it. Problem is it has a dead cylinder. Only running on three. Guy who has it did not even know. I took the spark plugs out and number 4 has no compression. Stuck valve? Guy still wants 3500 for it as is Tractor has been sitting for a number of years
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 6:39pm
Sounds like a good deal to me Mark L
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 6:48pm
Good thing it is not closer.I would buy it for that price.Nice looking tractor.That dead cylinder can be fixed.Hard to find low hour,staight tin and good looking rims.
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 6:55pm
My D14 had a dead cylinder when I got it. Turned out that a pushrod had gotten out from under the rocker arm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffrey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 7:00pm
Could it have original paint?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 7:52pm
What is the hose [hyd] under front of seat for? I don't remember that on my old D-15
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 7:59pm
If I had to guess, I would say that could be the original paint.  I would go for it, good tires, good rims, good tin, good paint, and three point.  If you drive it and it doesn't jump out of any gears and high/low works, go for it.  I'm sure that the dead cylinder is something minor on the top end.  Otherwise, ask him if you can take the valve cover off and take a look at things.  You should easily see if it is a stuck valve or rocker arm/push rod issue.  Man, that is one sweet looking D15.  Don't tell my D15, but that's a beauty!!
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 8:01pm
That sure does look like a nice original tractor! The problem is likely something simple, and as others have posted it could easily be valve train related.
Edited by BrettPhillips - 06 Mar 2010 at 8:13pm
Greg (Hillsboro, OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 9:36pm
I saw a D-15 series II on a trailer in Hillsboro, OH  today, don't know who it belonged to.  It was at an auto parts store.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 10:00pm
I see six bolt front hubs. If I am not wrong, that would be a late series 2.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2010 at 10:12pm
I'd bet on a stuck valve and a bent push rod.....you can gamble and hand him the cash, or ask to pull the valve cover and hope he doesn't see an easy fix....
ALLIS EXPRESS!
This year:
This page was generated in 0.049 seconds.
