Found a BARGAIN!! |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34132 |
![]() ![]() ![]() ![]() ![]() Posted: 06 May 2018 at 4:37pm |
Ran across this on STL CL.
1985 GMC 7000, 366 on Propane with an automatic, as it sits runs and drives $500. |
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
You selling?
Can't fix stupid
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88108 |
DANG........ got twice that just in tires !
I will be resurrecting the Brother In Law/his son our nephew's dump truck with this one!
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
Check the frame for cracks. A propane guy once told me that they quit running propane engines because they vibrated so much it would crack the frame welds.
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
engine should be clean inside with it on propane! nice looking truck anyways!
Hubert (Ga)engine7 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6486 |
That is a bargain! Good clean truck. And Shameless will be proud you bought a Chebby.
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5902 |
I think I would be verifying the Serial Number Title through local Police and also Carfax before I bragged too much. That may be more than just a 'steal' EG this 1985 GMC is priced a little bit higher ! $8,000 Gary https://columbiamo.craigslist.org/cto/d/1985-gmc-2500-rc-lb-price/6577406208.html |
HD6GTOM ![]() Orange Level ![]() ![]() Joined: 30 Nov 2009 Location: MADISON CO IA Points: 6627 |
John I ran one of those for 3 years. It did not vibrate until I lost the brakes one day. Was headed back to the shop downshifting to slow down. I was starting to turn in the drive at the shop, downshifted and broke the crank just ahead of the flywheel. It still moved but it did shake bad. Oil never got dirty, I used synthict oil in it. Should make a good truck for you.
truckerfarmer ![]() Orange Level Access ![]() ![]() Joined: 26 Jan 2013 Location: Watertown, SD Points: 3285 |
2 totally different birds. The one for $8000 is a pickup, he bought an actual truck. And just because they're asking $8000 don't mean it's worth that much, or they will get it. I bought my 1986 C70 2 years ago for $1000. Around here the going rate for TRUCK like that is $2500-6000 depending on condition a what bed is on it. |
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
I have a C60 that has no brakes, but I drive it anyway! bought it for $1500 when it still had brakes! is a gasser, bit runs good! 18 ft box and hoist on it.
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4543 |
Great deal. I had a 79 Chevy 7000 with a 366 and Allison automatic. It also had a 2 speed axle and air brakes. In its final years here I installed a 450 bu gravity bin. Two speed axle is great because in low it has gobs of torque for field work but will run out of RPM's at about 40 mph.
keeping the propane or converting to gas ?
Keeping the LP. Have the other beast on gas where have to drain the crappy stuff available EVERY time it has to sit long. Goes south and sour as if designed to at around 30 days.
LP can get a different set of tanks like a fork truck, mount a hanger and fill as needed where if shut off will not sour. |
