Found a 6080 |
Acguywill
Joined: 15 Jan 2024 Location: Vauxhall ab Can Points: 199 |
Topic: Found a 6080Posted: Yesterday at 12:43am |
Well we finally got one. Late model (deutz-allis stickers) with fwa cab and loader. Everything seems to work and it looks pretty good for a 40 year old tractor with 8000 hours on it. But I do have a question about the hydraulics. It has a homebuilt grapple on the loader controlled by what looks like a third factory hydraulic lever. Located on the right side of the seat and operated by pulling up or pushing down on it. Only 2 sets of couplers at the rear of the tractor, this is plumbed in somewhere under the cab. Is that factory or a dealer installed option or is it a custom deal?
cornel b
Posted: Yesterday at 10:32am |
6080 had a third remote option. maybe they just ran the hoses forward
4w-305 7040 6080 6060
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3643 |
Posted: Yesterday at 1:40pm |
Even though it is a late model - I would check the fore/aft play on the crankshaft. The late 4.33 motors had a double wide thrust - BUT, at high hours I would still check it. The front bearing set up can still be added. Congrats and just my 2 cents worth.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5458 |
Posted: 16 hours 31 minutes ago at 8:38pm |
I’m guessing a bearing support from a donor tractor? NLA from AGCO the last time I checked, we wanted to add one to our 6060.
Acguywill
Posted: 15 hours 54 minutes ago at 9:15pm |
Thanks for that. I looked it up on tractor data and it said 2 remotes. I have never seen one with a third remote before so I would guess it isn't very common? |
Acguywill
Posted: 14 hours 10 minutes ago at 10:59pm |
I did a quick redneck check for play using a manure tine as a pry bar before buying it. Couldn't feel any play and no leaks from the front seal so figured it should be okay. Anyone know the allowed amount of movement? We had one of these that we sold to an uncle probably 35 years ago that had 6500 hours or so on it at that time. He put another I think 10 or 15k hours on it before he scrambled the transmission and junked it. Other than a head gasket it had never been touched. So hopefully that is an indication of how long they can go without much work.
tbran
Posted: 35 seconds ago at 1:09pm |
End play about .004 - .010 - Think I remember if it is .1 the thrust brg lips are laying in the bottom of the oil pan.
