WD front V/S WC front wiight... |
472bigblock
Silver Level Joined: 14 Sep 2009 Location: Fletcher,Ohio Points: 86 |
Posted: 24 Mar 2015 at 1:16am |
I have Massey fronts that bolt to frame rails a lot lighter than any Allis frt. easy to install and have the five bolt car wheel pattern so you can run alu. car wheels lose a bunch of wt. 937-368-2447
cotncrzy
Orange Level Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
The one I replaced mine with came out of a styled WC. I could pick it up and walk with it. Im guessing 120# or so...
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
bmartin55
Silver Level Joined: 20 Feb 2013 Location: OH Points: 97 |
Unstyled wc front is light.,
Tracker77d
Bronze Level Joined: 11 Sep 2010 Points: 5 |
maybe already on here but do i need a styled or flattop wc front to make my wd lighter
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4429 |
Did you replace a WFE or NFE? |
bmartin55
I have a wd & put a wc narow front under it I lost 75 pounds. .so I got in 3500 classes mine weighs 3200 now
cotncrzy
Thanks out tp all.. I have done alot of searching, I see the unstyled front, it is considerably smaller. The WD45 IS thicker, I have one to compare to. The wd is some 3" thinner than the WD45, this WC I AM fooling with shapes just like the WD but is recessed back some 2.25 inches and "SOUNDS", lol! thinner???, when pecked on..
I was going to do the swap to try and gain 50# off my puller, and still might. I put the WC in the shop yesterday after it sitting out in the rain for two days. It was unbelieveable! It was stored without gas in it drained carb, etc.... I put gas to it, a battery in it, sanded the points and it didnt much more than turn over and it was running! Super oil pressure, the lift worked like a charm, pto is smooth. I compleete tractor with straight tin, a great restoration project!!!! It run for about five min. and I began to see coolant, the block is busted......, LOL, on to be a puller now... I got to put a shifter pin in the tranny shifter, its just going everywhere.This will be my first... Heard horror stories about this.
Orange Level Access Joined: 12 Sep 2009 Points: 19601 |
I always thought going from a tricycle WD45 to an old WC tricycle was about 100 lb loss. The WD45 is solid cast iron leaving just enough room for the steering gears and the WC is very hollow.
Fields
Orange Level Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Also rc wheels and 15" tires will lose about 20 pounds.
mattb
Orange Level Joined: 11 Jan 2011 Points: 348 |
try about 120
TramwayGuy
Orange Level Access Joined: 19 Jan 2010 Location: Northern NY Points: 11261 |
Maybe take off one wheel and hub? You only need one.
Larry(OH)
Orange Level Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1576 |
I am thinking around 50 or so
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
WF owner
My niece usually drives my WD45 in the 3500 lb. class, since I am very close on the weight.
I have a WC front end. It would be a lot easier to change front ends, than it would be to lose 50 lbs... |
Charlie175
Orange Level Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6351 |
someone posted before about this. I think the WC was 50 or more lbs lighter
Charlie
cotncrzy
I have saw it discussed, what is the weight difference in the wc front? looks to be hollowed out a little more, about two inches thinner? I need to loose at least 40#!
