7.3L project (not AC related) |
sks72107
Silver Level Joined: 30 Sep 2010 Location: Logansport, IN Points: 441 |
Posted: 17 Dec 2013 at 1:41pm |
So my AC friends im in the process of building a mechanical 7.3 powerstroke. All the machining is being done by my dad and i. Its been a long coming project, I first wanted to do this several years back at which time the project initiated itself. Im to the point now where its time to start building the injection pump. I already have an injection pump, but unfortunately its not ready to go which is why im here. Perhaps not the best forum to post this but i know there is some very knowledgeable people on here. The pump is already mouted, its just the internal working that im focusin on now.
The pump is originally off of a generator which was set to run at a constant RPM. The pump is a bosch P-series 79XX if i remember right. The plunger elements are not the proper ones for this application, being as they were for a generator. So the HP goal is a 600ish sunday driver. Im guessing 12mm plungers will do the job. Some parts im sure can be taken straight from the 5.9 guys. So first question, whats the part numbers to the plunger elements that the 5.9 guys are using?? Also I need to address the pump cam. The cam it has is designed to spin CCW, i need it to spin CW. I know bosch makes bidirectional pump cams, so can my cam be turned into a bidirectional cam? Delivery valves and what not be bought aftermaret. Any pump gurus here?? THanks
Its been a slow project, theres still a lot to do.
BennyLumpkin
Orange Level Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
What did the mechanical Powerstroke come in? I thought all Powrstrokes were electronic controlled injectors. A 7.3 IDI is all mechanical but aside from being the same displacement has basivally zero in common with a Powerstroke. Not saying I don't believe you, just curious what the engine came in, year, etc.
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
sks72107
Lol. A mechanical injection pump was not a factory option, but it sure looks good sitting in the engine valley.
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3746 |
there was a mechanical powerstroke writeup in diesel power magazine some time in the last year or so. maby you can search and find the owners/builders and get some advice. i cant say which issue or i would look but i have a whole stack
hypermax sells a kit to convert!! only $17K mabyyou could ask the tech guy some questions? Edited by CAL(KS) - 18 Dec 2013 at 5:01am |
CAL(KS)
just found in a search. the truck in Diesel power mag is called Double overtime.
for those unfamiliar and interested, there are quite a few pics around the net. mostly in pulling trucks 1500+ hp
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4789 |
I'm a pump guy, but am kinda lost in your description. You want to put a P pump on a 7.3, but it's already mounted? So you have an 8 cylinder P pump? Sunday driver? lol! 12mm big enough? lol! Been reading too many magazines. 10mm P pump is a lot of fuel on an 8 cylinder.
sks72107
Ed thats correct, I already have a pump and have it mounted, but the internal workings of the pump need to be addressed, i.e. elements, cam and DV's. As far as i can tell there isnt a big difference between cummins 5.9 and 7.3L displacement/cylinder ratio. This is why i thought 12mm would be a good place to start. It would seem as if the 5.9 guys start looking at 13mm plungers when they start shooting for the 1000hp area. Perhaps im looking at this from the wrong angle. And i dont read the magazines, ill put my money elsewhere.
injpumpEd
ok, sounds like you've done some leg work. What was the pump off of? The plungers the 5.9 guys are using are P7100 pumps, which dont fit into a std P pump anyway. Good thing, they're twice the price, and when buying 8, whoa! lol! The most important thing to consider when choosing a plunger & barrel, is whether it's a non retard to start. I wouldn't do a hi lift cam for something for the road. The cams are pretty aggressive already, and doing cam work would sacrifice longevity, with very little gain. Again, the pump you have may have some good usable stuff already.
sks72107
Thanks Ed that the type of info im looking for!! Someone with knowledge thats willing to teach a guy. This statement confuses me "The plungers the 5.9 guys are using are P7100 pumps, which dont fit into a std P pump anyway." I thought that all the inline pumped 5.9's were P7100 pumps, maybe a P3000 or a A-pump which we dont need to get into at this point. The pump im trying to work with was supposedly off of a generator, i dont know the exact application. If you are willing to look stuff up, I can tell you the numbers off of the houseing and maybe even the elements(thought they may have been stamped in the top cast piece). So, lets start with what i have and then we can go from there.
I originally found a smoking deal on an MW series pump that may have worked, but only fuel to about stock HP, and there really isnt much work that can be done to an MW pump. Then i kicked around the A pump, which i felt had some potential(and availability), but the plungers are limited to 10mm or 10.5mm. So i thought for reliability and longevity this may not be the best route. So i looked around a came up with the current pump i have.
I fully understand that the 7.3L is capable of making my power goal with readily available items, but this project has me hyped(and the wife is OK with it!!). And my dad and i have had a blast working on it together. Thanks for all your help Ed!!!
injpumpEd
give me the pump and governor numbers, and lets start with what you have.
2wise4agm
Orange Level Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
I don't mean to hijack this thread, but what are you doin for injectors. 7.3 injectors are huge in diameter, plus you have the hp oil galley in the heads to deal with.
Orange Level Access Joined: 12 Sep 2009 Points: 19632 |
Exactly. What about the injectors and cylinder heads??????
injpumpEd
usually adapters are made to fit a more traditional style injector into the large HEUI injector holes in the head.
sks72107
Yea pretty much what Ed said. My mind was turning one night and i thought of another idea for injectors. Its still a mechanical injector, but its homebrew and hasnt been put on a pop tester yet, but its getting very very close to working or back to the drawing board. I have some 8.3 injectors that can be made to work if all else fails.
sks72107
Ok, fun being an LP driver this time of year......
the pump numbers are 0 402 618 813 PE8P120A500/4LS7935 if nothing will work in the pump, I won't shed any tears. |
injpumpEd
ok, the PE8P means is's an 8 cylinder P pump, cradle mounted. 120 means 12mm p&b's, but likely to have retart to start notches. 500 has to do with feed pump orientation, not sure what 500 is, 2 feed pumps maybe? The LS means that it is left hand rotation, or counter-clock-wise looking from the front. The 7935 does indicate a 7100 style. I do have access to some aftermarket 13mm p&b's for this pump. Now how about the governor tag. I'll get a parts breakdown when I can, with the holidays coming, my suppliers are on short schedules.
studer automotive
Orange Level Access Joined: 10 Sep 2013 Location: jeromesville,oh Points: 558 |
I've owned and modified a several ford idi 7.3's.if this is indeed a idi 7.3 you never made mention of a turbo?? if it has a turbo 10-12 lbs are all these motors can take..... for very long. the cam shaft will need changed also. even with all the mods those motors never did make real big power. I believe 350-375 h.p. is possible. just my 2 cents
a-c 185-d y/r cab turbo soon
99 f-250 7.3 4x4 86 mustang5.0 owned since 8/93 |
