compression ratio question |
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
Posted: 11 Aug 2013 at 12:15am |
I am attempting to build an engine with 4 1/8" flat top WD pistons (not M&W) and a WD45 crankshaft. What is the compression ratio that this arrangement will produce? Thanks
www.awtractor.com
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22816 |
Orange Level Access Joined: 12 Sep 2009 Points: 19637 |
It will depend upon which piston you are actually using....compression heights will vary somewhat from one vendor to another.
patrickmull
Orange Level Joined: 11 Jan 2011 Location: Casey IL Points: 893 |
my first pulling tractor a 37 wc was set up like this it had a mag i hand cranked it
cotncrzy
Orange Level Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
I set my first engine up like that, we figured it 9.5:1 or so. Had 140 psi cranking compression. Way up from 100, where it was.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
A model One-Seventy gas has 8.0 to 1 compression and will crank at 170 to 180 psi with electric start.
cotncrzy
We wasn't sure of the math Dr Allis, I have spoke with others after the engine was assembeled that agreed we were close to that. So, I stand corrected on the ratio, we were still useing the old hand crank to turn the engine though, might of made some difference.
wi50
It will depend on your pistons original compression ratio, but putting that taller piston on a longer stroked 4.5" crankshaft will boost it a fair bit. It's easy to figure out if you work the numbers backwards.
I just ran some round numbers for comparison, the higher the original compression ratio, of course the higher the ratio will be when swapped to the longer stroke, but it grows exponentialy because of the added swept volume and the lesser compressed volume. Just for example if you originally had a 6.5 to 1 compression ratio with the 4" stroke crankshaft by simply swapping that piston to a 4.5" stroke crankshaft you have a 10.5 to 1 compression ratio. If it had a 7 to 1 compression ratio the swap will yeild a 12 to 1 compression ratio. If you have an 8 to 1 compression ratio originally, the swap will yeild about 15 to 1 comperssion ratio.
If you hand crank to test, it will show weaker than it really is. If you have the throttle at an idle, it will show weaker than it really is. Open the throttle wide open and put a chain on it and pull it with another tractor to get a good compression test.
mike a
Bronze Level Joined: 12 Dec 2009 Location: MN Points: 164 |
i put wd dished in my e-gleaner engine,cranks 175 psi.
cotncrzy
I will say this, the first build wouldn't run on regular gas. Well it would run but knocked and had to choke it out, the ignition wouldn't kill it.
Alex09(WI)
I measured the compression height of the piston and as far as I can tell it is 2.465" from the center of the wrist pin to the top of the piston.
www.awtractor.com
Hudsonator
Orange Level Joined: 21 Oct 2009 Location: Tennessee Points: 2113 |
Its been so long ago, I cannot remember the compression height of the pistons in my own "first build". But, they were TISCO WD 4.125" diameter pistons for 4000' altitude. They were originally bought around 1969-70. At the time I obtained the pistons/sleeves (1985), the guy stlll had the original tag on the box - so I'm positive of what they were.
They had "power crater" type tops that were fairly deep, with a much narrower flat-band at the edge than Allis Power Crater pistons. The only measurement I can remember is that the piston edge was 1/32" from the deck.
When fresh, it made 280 psi on the compression gauge -being pulled vigorously in 4th gear with the throttle wide open. It would only run/crank on 110LL aviation fuel without complaint. It was a hand cranked, mag fired tractor built to scoot within the rules circa 1986. Here's a picture of it in its heyday - 1990.
Cheapest fun I ever had - for 17 years.
There isn't much a WC can't do.
WD's just do it better. |
blue924.9
Orange Level Joined: 22 Mar 2013 Location: George Iowa Points: 1082 |
nice I like the look, everything tractor background, everything
