E Gleaner Engine
Message Reverse Sort Order
THE-MAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote THE-MAN Quote  Post ReplyReply Direct Link To This Post Topic: E Gleaner Engine
    Posted: 24 Mar 2013 at 9:46pm
And it is an absolute fact that mlpankey uses a tape measure to measure a bore. Therefore based on the bore premise and his deck height fallacy, he most be using said tape measure to measure deck as well. Not arguing, just validating more fact and logically using his illogical ways and means to reach the proper conclusion concerning his apparent dis-abilities In simple math.
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 8:54pm
Originally posted by mlpankey mlpankey wrote:
according to the manual wrist piston pin is .9999-1.0002 =1.00 inch to most  block is 12.656 height as well. not arguing just correcting
Wrist pins are .990". That's .010" less than an inch. Measure one. Block deck heights are 12.625" if you use the sharp points on your caliper to measure from the main bore to deck and add half of the main bore diameter. If you use the wide part of the caliper jaw for inaccurate measurments then you'd probably get something like .030" more or 12.655.
Close enough if all you have are tape measures and angle finders to compare engine parts. Not argueing either, just validateing the facts.
Ihateillinoisnazis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ihateillinoisnazis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 9:52am
Pankey again proves to fill the forum with erroneous information. Not arguing, just stating a fact ;)
Post Options Post Options   Thanks (0) Thanks(0)   Quote THE-MAN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2013 at 8:42am
Odd. All 7 or 8 I've measured were about 12.625 or 12.63. Not arguing, just validating wi50's response.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2013 at 12:45pm
Breeze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Breeze Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2013 at 2:46pm
AlVee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2013 at 12:47pm
i found these nice aluminum connecting rods on ebay might be something that could be used i see they have all different lengthseven 1 set with 7.5 length just info for you to ponder
http://www.ebay.com/sch/m.html?item=190704528900&pt=Race_Car_Parts&vxp=mtr&hash=item2c66e02e04&_ssn=shpcvolpe12&_pgn=2&_skc=50&rt=nc
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2013 at 6:45am
10 inch
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
The Other Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Other Orange Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 11:55am
What is the size of the wd clutch?
Edited by The Other Orange - 22 Feb 2013 at 8:13am
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 7:59am
Typical take out head gaskets are a tad over .060. New Fel Pro are .062 and compressed about .055. The Victor gaskets are just a few tho more.
I just figure .055 to .060 when doing the math.
Of all the blocks I've measured 12.625 and occasional 12.63. I just use 12.61 for any of them getting decked to clean up after installing larger sleves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Other Orange Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 7:52am
Thank you Sir
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2013 at 6:27am
Wrist pin is .990
Rod journal 2.375
Rod length 7.5
Block deck height 12.625
Piston compression height varies a little depending on the engine, also the pistons are dished.   A few times someone has posted some drawings of the pistons, a search should find them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Other Orange Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2013 at 9:51pm
I'm looking to do a little research on my own. Would somebody like to share info on the key components?
Block Height
Rod journal dia
Rod length
Compression Height
Wrist Pin dia
I found a Wd with this engine in it. It's been sitting for 25yrs. I've built Oliver's, coops, and Massey engines. I would like to build a allis this year.
