Counterweighted crank |
Post Reply | Page <1234 7> |
Author | ||||
CTuckerNWIL
I think all but one of us Know who's firing order isn't right
Sponsored Links | ||||
Butch(OH)
Orange Level Joined: 11 Sep 2009 Location: Lucerne Ohio Points: 3831 |
Proof positive that people who actually know something can explain the complicated in simple terms. We now await the VI and a 1000 word response,, with no periods, commas or capitalization. |
CTuckerNWIL
"Some are given to prophecy,
Some to invention Some to leadership However some were placed here simply to move heavy objects" Yet others we can just wonder about |
mlpankey
Orange Level Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
AC200Puller
Orange Level Joined: 04 Dec 2011 Location: Wisconsin Points: 774 |
Wi 50 what are you building for a tractor ? I would like to see the finished product always great to walk around a fine piece of equipment and drool!
Ihateillinoisnazis
Orange Level Joined: 15 Jan 2013 Location: By The Lake Points: 273 |
Pankey, I asked how the firing order effects "BALANCE" of a rotating mass. Not how it effect vibration.
That paper talks about modal analysis of a crankshaft, which by the way is finding the natural frequency a material, object, or structure vibrates at. (Everything has a natural frequency) By testing different firing orders they are making the crankshaft "ring" at a different frequency. If you make the crankshaft "ring" within it's natural frequency vibration amplitudes will significantly increase. (10-30x increase vs not in the range of resonance) So once you know the natural frequency of an object you can change it by adding mass, increasing stiffness, or in the case of the paper avoid the resonance range by changing the firing order. We all know when things run smooth they last longer. (Unlike that crank pulley you tried to balance) Balance is a topic I will let you explore on your own. The way you appear to balance cranks is discussion for a whole new topic. A little secret to start you off, you can't balance a crank on a single plane (Ex: welding gobs of dung to a crank pulley). There's a big difference between vibration due to resonance and vibration due to imbalance. Keep trying Spunk.
Ihateillinoisnazis
Oh, Pankey please stop PM'ing me about this. I'd much rather keep this discussion out in the public :)
CTuckerNWIL
I can just about bet Pankster was a professor of matrix algebra at the U of Panky and understands all this paper talks about I read somewhere in there they were using 1900 rpm too.
Rod B
Orange Level Joined: 25 Jul 2011 Location: Peoria Points: 415 |
I asked those questions to see if you knew anything about balance pankey. You said you didn't, and now are showing your lack of experience. That article only backs up what wi said. Fireing order doesn't effect balance.
Nice try but you're still wrong pank. Edited by Rod B - 19 Feb 2013 at 6:07pm |
mlpankey
Industry standard is to reduce bob weight and since the counter weight represents 50 percent of the bob weight in most instances it will reduce also but marty defys some industry standards while concuring with others. I think btyant cranks spends enough on r and d to buy most of the wisconsin farms up with their virtually no counter weights and hollow rod journals but yet marty goes in the opposite direction. Read the link it supports the industry standards and firing orders
Ihateillinoisnazis
Do I spy with my little eye... Balance weights on a Bryant crank???? Hmmmm Also Pankey, that link you posted and refer to so often, Did you read it at all?
mlpankey
[QUOTE=Ihateillinoisnazis]
Do I spy with my little eye... Balance weights on a Bryant crank???? Hmmmm Also Pankey, that link you posted and refer to so often, Did you read it at all? [/CRANES] so you pull a picture of a bryant with small counter weights now slug it with mallory when you cant hit their target bob weight. Oh wait if you had one you would have the warning not to but to externally balance when target bob weight is not attainable.
Ihateillinoisnazis
Dafq are you taking about? Really.. quit rambling, post something useful, or go suck on a slug of used uranium or something.
mlpankey
Ok i am smarty marty the air flow expert i am going to turn my engine at least double to three times its factory rpm. I have this 1 1/2 hp cnc that can mill out a harder material than factory rod so i can slim line it while making it longer so its still 50 perzent lightee than factory. I then can run a 50 percent lighter piston and ring package. Cause i raised the pin location and dont need the heavier wider rings after all a thinner ring is a better seal. Now necause i am going to turn it so much harder i am going to add more weight to the counter weight.which already represents 150 percent of my bob weight. So know i am 250 percent over my bob weight with my superior weight adding skills and that is going to reduce any damage caused from vibration.lol
Butch(OH)
You don't even know enough about balancing to have fun with That statement (and the other you just posted above this) is just a jumble of words you have heard somebody in the
balancing room say and assembled them into senseless BS.
For you and the ones that might be confused by your foolishness, here is
balance primer 101 so at least next time you dont make a total fool of
yourself. We are going to use a single cylinder engine here for simplicity but the math and terms cross to others What makes the engine vibrate and thus the need of something to balance it
is two things not one. Rotating weight which is a circular vibration and non-rotating weight such as the piston. The rotating weight is easy, you place a weight, aka counter weight opposite and problem solved. Now there is two problems left here. The piston is going back and forth causing a vibration in line with the bore and you have the rod which is what??? It is neither in total. The pin end of the rod is more or less non-rotating and the big end is more or less rotating, Since the entire balancing job must be done on the crank how are you going to counteract the piston??. Huh?? The piston go up and down and your balance weight go round and round Pank??? The answer is compromise, or in balancing lingo "percentage". You cancel out part of the piston but not all of it or the engine will simply vibrate in a 90 degree angle to how it vibrated when unbalanced. The bob weight whose purpose you totally butchered is nothing more than a calculated weight used to balance the engine. Is not some number you shoot for when building the engine. It is the total of the rotating weight, plus a percentage of the non-reciprocating weight added to it. This would be the bob weight which is hung on the rod journal and you balance by adding weight opposite aka counterweight. So naturally when a smart builder uses the lightest components that will hold up to his use the weight of the bob used to balance the engine will be lighter. An under balanced engine (by percentage) will vibrate inline with the bore, an over balanced engine (by percentage) will vibrate perpendicular to the bore and this even changes with RPM once you are close. Somewhere in between is the best we can do. Obviously this is many feet above your level of understanding Pank but maybe others will benefit. What WI50 is saying is with no counterweights on the inline 6 you must transfer all of these forces through the crank to the piston that is going in the opposite direction. In the case of number 1 that would be number 6 Pank, all the way at the other end. #2 is countered by #5 and #3 by #4. Isnt hard to see why at his HP levels that would twist and break cranks. Wasnt it you who just today said that timing at individual cylinders was like the holy grail of found power?? Now you say it is better to use the crank as a torsion bar to balance the engine than to balance it at each cylinder and eliminate the twist??? Please make up your mind and argue one way or the other I get dizy easily. The builder you mention and most others will mention a bob weight because they don't want the counterweights added to or subtracted from excessively and compromising the crank, this is why they offer several bob weight ranges in popular strokes. If you are building the entire engine in the shop like Marty you simply design the crank weights around the parts that make to power, not the other way around, One of these days, maybe,,if you ever build engine #2 and get your head out where the sun shines. You will learn that what you learned on #1 does not apply across all engines, all applications, all HP and all configurations,,,, , Remember #1 went 5 runs and KABOOM!!!! Sorry guys just in one of those moods today I guess? Edited by Butch(OH) - 19 Feb 2013 at 9:14pm |
Rod B
This pankey fool knows just enough to get into trouble but not enough to get out.
Ihateillinoisnazis
Butch, good exination.
When dealing with spank we need to remember this is the guy who believes in forged cast rods. Edited by Ihateillinoisnazis - 20 Feb 2013 at 7:36am |
mlpankey
We will be doing some crankshaft comparative balancing analysis in a few weeks. Class will be 250 a person space is limited . Lunch will be served sweet tea and bbq. The comparitive analysis will be a inline 4 cylinder crank shaft externally balanced with no bob weights at first then introduce bob weights to see if any change to balance occurs. The other analysis will be rod journals being moved to center up rod to bore effects has on balancing . sign up now. If you would like to check a six cylinder crank bring the crank harmonic balncer flywheel clutch pressure plate and either the bob weight in grams or rod and piston assembly for us to weigh. on inline you dont suppose to put bob weights on them. on a v8 the big end doubles but not on a inline only one rod per throw . big end is rotating weight the little end is recipicating. there is such a thing as over and under balancing it is directed by rpms.
Edited by mlpankey - 20 Feb 2013 at 7:53am |
Ihateillinoisnazis
What's this "we" sh!t? You got a mouse in your pocket?
We all know you can't teach a class. You can't even teach bullsh!tting, you're bad at that too! Edited by Ihateillinoisnazis - 20 Feb 2013 at 7:59am |
wi50
I'll save you fella's the $$$. I'll show you for free what pank's cranks can do for you. The real question is did pankey do this himself, or was it the work of his immaginary shop? We leaves me wondering if the neighborhood toddler was playing with sparklers and the result was this....
They can weld nuclear waste on the wrong side of the pulley to balance it. But with a double imbalance (like a double negative in mathmatics) I bet it will vibration harden the rods, maybe even throw the timeing back into being spot on.
Your lawnmower blade balancer rusted up a little pank? Edited by wi50 - 20 Feb 2013 at 8:33am |
Butch(OH)
Marty,
The balancing blobs are a notch above the wheelie bar blobs at least, LOL
mlpankey
thats weight . for a externally balance crank . but marty makes comments that you cant externally balance a crank. he obviously never drove a ford 302 . it never slung the weight . now you fellows runing elastic harmonic balancers might need to be cautious of slinging the outer ring
Edited by mlpankey - 20 Feb 2013 at 8:52am |
wi50
yes they are a notch above... wheelie bars tend to be close to the ground, at least that's where I'd put them. The crankshaft is typically much higher in the vehicle with it's centerline the same as that of the driveline
With pankey's measureing skills I now know what a "notch above" means. I'm guessing he has notches cut in a stick rather than micrometers and calipers.
Unless of course you wish to ask how far you could move the crankshaft down in it's bore and still not have timeing gear issues, input shaft problems, or whatever else he wasn't thinking about in his "topfuel machining" topic.
mlpankey
wi 2 percent over 50 percent(neutral balance) is a overbalance what ever measuring tool you use. your doing well keep moving away from the racing industry standards .I will keep following them . Cause I have been through the follow the leader stuff. Its commical when you find out everyone was doing counter weights due to the fact the leader just cut some out to shape with his torch.
Edited by mlpankey - 20 Feb 2013 at 9:40am |
Ihateillinoisnazis
Spunky, you never cease to amuse. At least this forum has that going. FYI externally balancing a crank is a manufacturers way to save costs. Since you couldn't understand this I the con rods post cost savings is what keeps manufacturers such as ford and Chevrolet in business and competitive. Sometimes manufacturing techniques aren't done with performance in mind, rather the bottom line.
Keep piling pigeon sh!t on your crank pulley and we will continue to watch you huck rods out the bottom. As for following the leader, you should try it sometime. You might get somewhere in life. Your not a leader. Well I take that back, you are the resident idiot around here. I'm sure no one else is claiming that title for themselves. |
Larry W.
Silver Level Joined: 07 Nov 2010 Location: Luck, WI Points: 278 |
I find it so comical that pank has yet to build a naturally aspirated 4 cylinder antique that makes more then one or two hooks, but yet he seemingly is more knowledgeable then all the guys building the top performing superstock motors in the ntpa! Pank you are arguing that what Marty is doing is incorrect, even though its the exact way a super motor is built. Dude this is not a wd allis or a 292 Chevy six! Either build one and come beat Marty heads up like a man, or shut up and stay in the corner where you belong.
Butch(OH)
You sir have obviously not read the post where Pank told the world that he is the smartest person on this site! Please go read it and then come back and show proper respect |
wi50
pank posted this yesterday morning, today he thinks he's an expert.
the only way one of these engines is going to stay alive is to counterweight the crank.
And now to make pankeys head spin a few times, the new rod weighs 1960 grams. The OEM rod is about 6500 grams..... the crank stroke is the same, 4.75". Tell me how heavy the big end of the rod is? The big end is the one that attaches to the crankshaft (rember, someone had to explain it to you in the connecting rod thread)
And one more thing, the engine has a 2.2 to 1 connectiong rod length to stroke ratio...... Edited by wi50 - 20 Feb 2013 at 11:29am |
CTuckerNWIL
How about the post where he said he was the most quoted person on here. Sometimes he quotes himself without adding anything so I guess that is possible
Ihateillinoisnazis
I wonder what calculator spunky will try to plug Wi's numbers into?? The spankulator9000, defies all things physics and common sense.
