cylinder hone grit |
nickia
Orange Level Joined: 11 Sep 2009 Location: alden iowa Points: 762 |
Posted: 30 Apr 2024 at 9:40pm |
I finally got dads old D-17 gas freed up. The head is off and want to clean up the cylinder that was stuck. What grit of stone are people using to clean these up? I know it will probably use a little oil but dad is 84 and getting out of the hospital and will not get worked very hard at all just plan on using it on a rake. Kind of a surprise for him as its been sitting for the past 5 yrs
nickia
I was thinking 180? Rabbit t**d hone? Any thoughts
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78136 |
YEP... thats what i would do in your case... Could be 240... but the 180 might clean up more of the "damage"..
nickia
thank you ive used the rabbit t**d hones before and the work rather well just couldnt remember what the final cross hash marks should be
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3304 |
clean al then rust and crud out first or you will fill the hone up and it will hone the clean spots and not the dirty spots
KJCHRIS
Orange Level Joined: 21 Dec 2015 Location: WC Iowa Points: 832 |
Do you know anyone near you with a sandblast cabinet ? use it first and only to remove heavy scale, it will save time and the hone.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4438 |
If it's just 1 cylinder, you might just replace that 1 sleeve with a good used 1.
I personally would use a flat stone hone because it will only hone the high spots, not make the low spots lower.
