Grandfathers CA |
Post Reply | Page <123> |
CA13414
Bronze Level Joined: 25 Feb 2024 Location: Nebraska Points: 61 |
Well at the end of the day it was a blast to hang and work on the tractor!! Here is a video of me driving up the hill in 4th gear..... Yes I definitely date myself with the tag line of a long ago sit-com. :')
Make sure you turn up the volume. Edited by CA13414 - 31 Mar 2024 at 9:26am |
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3657 |
Thanks(1)
That 'ol girl sound pretty healthy!!
wjohn
Orange Level Joined: 19 Jan 2010 Location: KS Points: 1812 |
Agreed! It sounds like it's running well.
CA13414
Pulled the gas tank and will sand blast that with a bunch of other small parts.
Also took off the brakes. The pads were quite worn and broken up. "Drums" do look good, not 100% but reasonable for now. Do appreciate the prior owners who drilled out the middle side of the pins. Was easy to remove after a couple of days of panther piss. However, there was a ton of dirt, oil and etc which made it a challenge to remove the pads due to the space being full of organic material. We prevailed. Next is to remove all other sand blast-able parts including the tire rims. Edited by CA13414 - 07 Apr 2024 at 9:41am |
CA13414
Stripped down a bit more..... almost as far as we go in that regard.
One of the major oil leaks is the hydraulic system. It is coming from the upper side. Not sure exactly what it will be but suspect an "O" ring is bad. Here are a few of the last parts for sand blasting. Was a bit of a pain, but removed the spindles out of the front end. Next to remove the old spindle bushings and press the new ones in after cleaning them up. Overall a very productive day. I think we have found all but one oil leak. This is on the left side and leaking between the differential and final drive housing. I suspect it is the inner oil seal for the upper drive shaft which was leaking into the left housing. Here is the brake pad that was buried in dirt and leaves in the housing and soaked with oil. < id="idg-io-safe-browsing-enabled" ="" oninit="true"> Edited by CA13414 - 07 Apr 2024 at 9:42am |
CA13414
The last parts to remove for sand blasting are the steering shaft and tool box. Then we will clean the rest with wire brushes and cleaner.
At this point the only other thing we have noticed is a small antifreeze leak from the upper seam of the radiator. Hope it is a quick fix with the MAP torch and solder. Edited by CA13414 - 09 Apr 2024 at 8:08pm |
CA13414
Removed the battery box, tool box and steering column/shaft.
Need to figure out how to tighten up the steering boxes to take out the extra play. Edited by CA13414 - 09 Apr 2024 at 8:12pm |
dfwallis
Silver Level Joined: 09 Mar 2023 Location: DFW Points: 333 |
Steering play adjustment: That would be interesting. Mine seemed to be all related to gear teeth meshing.
CA13092
CA13414
Indeed, after reading, this is not adjustable. Will make sure there is oil/grease and clean it up. Will see what it looks like after we get the front put together. Overall it is not terrible, thus, maybe will just hold on anything else for the moment. Edited by CA13414 - 10 Apr 2024 at 5:47am |
CA13414
A few more pictures.
Radiator is off, now need to pressurize and find any leaking spots. Hope to fix vs. buy a new one for ~$200. :'| Wiring, generator and starter are now off. We set aside the wiring as a template when reassembling. I have new wire and connectors with heat resistant black wrap. Was able to remove the front spindle bushings and clean up the spindles. Do need to use a bit of emory cloth to finalize before assembly. Did find out the mid steering box is adjustable. An 8th of a turn took out almost all of the slack. Need to check/add oil grease. This week we will pick up a new rear tire. One is in good shape the other has many cracks. Realized our center pivot tires on the farm are 11.2"X24" and plan to use one of those tires. I did find many on FaceBook for $50 or more which would also work. Ironically, when I was looking at the other rear tires to see if I should replace it I realized it was also an old pivot irrigation tire! Next steps: Continue clean up!! Press in the new spindle bushings, reassemble the spindles, rebuild/repack the the front wheel hub bearings and with new seals reassemble. Then swap out the front end. Edited by CA13414 - 14 Apr 2024 at 1:23pm |
Ted J
Orange Level Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18727 |
Thanks(1)
You're doing great and the pics help immensely. Keep at it!! They are a real pleasure to work on and an even better one to drive!
CA13414
A bit slower progress this week.
Spent the day cleaning. With a putty knife, screwdriver and wire brush, took all the "chunks" off the engine, torque tube and part of the transmission and differential. Cleaned up the air filter and should be ready for a bit of sanding and then paint (planning black). You just gotta love "Brake and Parts Cleaner" for removing the oil and grease as well! Pretty much strips off everything which was awesome. Here is air filter, ready for sanding and then paint. The engine and torque tube! Torque tube and steering box! Transmission, differential and PTO/hydraulics!! A bit backwards, but before all the above, we spent a few hours cleaning. The results of the day were achieved by the right tools and as previously note...... brake and parts cleaner. Notably the best kick ass tool of the day was..... a cordless Milwaukee Hand grinder. This was awesome to clean up the rest. The Milwaukee drill with a SS wire bur was also a huge thumbs up!!! Replaced the gasket on the oil filter mount... which was leaking. Also took off the radiator support to check out the front steering bearing cone and capscrew. There was oil present and no notable issues. Decided to leave it as is and not dig deeper. Thus, filled it with Lucas Hub Oil and made a new gasket with the ball ping hammer. Will watch and make sure there is no oil leak (if so replace the oil seal). Also filled the steering box with Lucas Hub Oil and will check for leaks. Still need to dig into the hydraulic system and find the suspected bad "O"-ring. Then the inner final drive seal need to be replaced!! Edited by CA13414 - 20 Apr 2024 at 11:45pm |
CA13414
Spent the rest of the day replacing electronic hardware at the house after a lightning strike . It took out our internet router, network switch, all the TV's, my Hubitat Hub, security cameras, smart switches and a few sound system amps. Thankfully, furnace and appliances are OK. Thank goodness we didn't have a fire or anything more serious!!! Edited by CA13414 - 20 Apr 2024 at 11:57pm |
CA13414
Paint!!
Thoughts on the following..... Planning Persian Orange #1 and black. Black paint: Air filter, front wheel hubs and lug bolts (rims are orange), rear wheel power rims (inner to be orange), steering shaft, gear shifter, hand clutch lever, alternator and starter. Orange: Everything else. Thoughts??? Edited by CA13414 - 20 Apr 2024 at 11:56pm |
CA13414
Also, any insight on this engine block number? Found it when cleaning. Mostly currious!!
Edited by CA13414 - 21 Apr 2024 at 12:30am |
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4428 |
It's your tractor and you should paint it whatever you want, but there was nothing painted black when it left the factory.
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3475 |
Keep up the good work, will be a nice one when you're done.
CA13414
Ready to remove the front end and clean up everything under the front steering.
We pulled a couple of cold rolled angle iron from the iron pile to support the front end while we rebuild and change out the front axil. Didn't take much with the drill press and pilot hole and a 11/16" bit. Bought some 5/8" schedule 8 bolts and put it all together. A piece of C-channel at the base wire welded, to fix the base, just because!!! Edited by CA13414 - 25 Apr 2024 at 8:06pm |
CA13414
It has been a sad week. A tribute to "Jax"! Was an awesome English Cream Golden Retriever.
He was 82 years old in human years!!!! An amazing family member. Yes, he is chasing rabbits in the field!! Yep even like the cat and the cat liked him!!! Edited by CA13414 - 25 Apr 2024 at 8:13pm |
IBWD MIke
Golden retrievers are just great animals, sorry for your loss.
CA13414
Thank you! He was such a great dude. We miss his "ever-presence" or as we always say that he was ....... "under-foot!"
Edited by CA13414 - 26 Apr 2024 at 10:11pm |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78075 |
Sorry about the pup...
You do a good writeup on the overhaul.. Pictures are GREAT... Would make a good BOOK !
CA13414
Thank you!
It has been fun to "document" the journey. Family and friends are following along. It has been about..... bringing back something that reminds us of our Dad and Grandfather and the family farm which was homesteaded by my Great Grandfather almost 150 years ago. While I will not use the CA as my livelihood like my Dad and Grandfather, I love that it is still used and part of the family. < id="idg-io-safe-browsing-enabled" ="" oninit="true"> Edited by CA13414 - 26 Apr 2024 at 10:30pm |
CA13414
As most of you would guess....... with a farm that has near a 150 year history, we now need to decide what to do with the numerous vehicles and many, many other old long abandoned tractors and implements that have been used over the past 150 years. We have everything from the horse drawn plow which is now the mail box, to modern equipment. It is a constant clean up and my Sis has been awesome!! Still have my 68 Pontiac LeMans I drove in High School (it is not salvageable due to rust). We rebuilt the engine, added a low ratio Muncie transmission and changed to a 4.88 rear end. Was a rocket off the line with 12' slicks!!! Was pretty sly and never really got in trouble..... or caught.!!!! My driving: After the green light, the clutch is not needed!!! Edited by CA13414 - 27 Apr 2024 at 3:21pm |
Ted J
Sorry for your loss of your best friend. I still look down so I'm not stepping on ours. On the oil filter mount, take a straight edge and check the mount. A lot of times they are 'warped' because of over tightening the two bolts, causing them to curve. A little flat file on em works good. A family heirloom is a wonderful thing!! Think about how the farm went from horses to where it is now. Things have gotten a lot easier!
CA13414
Thanks Ted, I will check the filter mount with a straight edge. It didn't look bent, but I was probably looking through my bifocals thus, who knows. :')
It is really impressive how it changed within 3 generations starting with the horse and manual labor... Today it is still hard work but as you mentioned easier to get things done on a larger scale. Amazing to think that the CA was ~$1,900 in 1958. In contrast:
Edited by CA13414 - 27 Apr 2024 at 5:09pm |
CA13414
Of interest I used an inflation calculator and $1,900 in 1958 is worth $20,533.94 today.
Thus not too far off for the HP purchased. Edited by CA13414 - 27 Apr 2024 at 4:09pm |
CA13414
Next step in all of this was to find a solid 3-point 6'-blade for maintaining part of our property. Just picked this up this morning after a purchase via MarketPlace. Was a fun 90 mile road trip into greater Nebraska.
Was a pleasure visiting with the gentlemen selling the blade. Cheers to their spectacular and beautiful country home. Is a historical house that is amazingly maintained. Edited by CA13414 - 28 Apr 2024 at 11:46am |
CA13414
Today was able to spend a few hours. We took off the old, bent and welded front end, and put on my GrandPa's/Dad's front end.
Here is the old unit (snagged the hubs and wheel bearings which look to be in condition). Here is sand blasted and primed front end from my family CA. Next will be to put on the spindles and hub after repacking. Edited by CA13414 - 02 May 2024 at 10:00pm |
IBWD MIke
Did you change the bushings in the knees? Perfect time to do that.
