Two speed for D17 |
gcalent
Bronze Level Joined: 19 May 2010 Location: Willards, Md Points: 179 |
Posted: 06 Feb 2024 at 11:03am |
I believe it has been done, I would like to convert the power director clutch to a manual shifted two speed without the clutch discs.Any help would be appreciated
Pullin With AC
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4388 |
My question would be why?
The power director will hold a lot of power and is relatively easy to rebuild. Unless, you are planning very extensive engine modifications, a power director should handle all the power a D-17 engine (gas or diesel) would have. When pulling, you can leave it in either high or low, which you would have to do with a mechanical two speed.
gcalent
Extensive engine mods, I'm no sure the clutch package will hold
Pullin With AC
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3241 |
We pulled a D17 diesel IN THE '70'S - two turbos - always started the sled with hand clutch running ATF - bolted up the foot clutch. 7th gear in 5000 class. Unless you are turning over 4000 rpm the PD clutch will not be an issue. Just as with cast iron flywheels - the clutch is cast iron as well. If still have doubt - find a D19 unit - it has 5 plates in the low side 4 high. (and no we could not keep the head gasket sealed )
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
Boy Tim! You guys had some wild hair days back when.....
tbran
I have a picture on home computer - will try to post.
Macon Rounds
Orange Level Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2058 |
Put a D19 PD in it !!!
Been there done that !!! It is EXACTLY the same design. Just has more clutches. And you wont loose the ability to shift on the fly. |
