Flathead generator |
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2516 |
Posted: 09 Jun 2023 at 10:38am |
Fav son found an old generator buried in the dirt way back in the woods . Just curious as to what it came off ? Found 21 A 42 10139 on it , which seems to have been on a 1940ish Ford flathead car . Probably have pics up soon . Anyone have a clue ? Thanks !
WeisAC2
Bronze Level Joined: 02 Feb 2017 Location: Aiken SC Points: 110 |
ACinSC
There it is , looks like it's been buried a while . Thanks
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77615 |
http://www.allfordparts.com/
again... click on this link and it will appear in the link bar at the top of the page... delete the %20 in the link and hit ENTER... you will be at the ALL FORDPARTS page.. go to page #7 for a drawing of the old generator............ and for some reason that site does NOT want to link... here is a screen shot.. Edited by steve(ill) - 09 Jun 2023 at 1:13pm |
some parts are available....
type in "ford generator 21 A 42 10139" in the LINK BOX at top of the page and you will get a GOOGLE SEARCH of several sites... ( if you use GOOGLE).
ACinSC
Thanks Steve, good info. Sure would like to know how it got where it was. Maybe 🤔 someone was off roading? Always heard Uncle had a still back there years ago
ACinSC
Pulled generator apart and it has/had some kind of cloth inside ? What the heck was that for?? Thanks
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3647 |
The field coils were originally wrapped in a cloth material to insulate them from the body of the generator. It tends To come apart over time in conditions such as you found that one!
Edited by Alberta Phil - 11 Jun 2023 at 8:23pm |
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21443 |
The sad thing is I have TWO of them, in 'ok' condition in the garage attic...... they'll have to 'go to China' as I was told my stuff next door HAS to be removed...
ACinSC
Thanks for the explanation Phil. Learn something every day.
DonBC
Orange Level Access Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 899 |
That long mounting bracket allowed it to be moved up or down to adjust the tension on the V-belt that went around the crankshaft pulley, the water pumps on each side of the 'V' and the generator on the early flat head Ford engines. I had lots of first hand experience with these engines.
ACinSC
Thanks Don. Been wondering about that.
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9620 |
My first car was a 1953 Ford convertible with the flat head V8
DonBC
Henry Ford was intelligent and frugal. The first V8 engines were largely based on the castings for the model A flat head four. One side was mounted at 45 degrees and the second side was essentially a mirror image of the model A casting mount 45 degrees the other way and offset by the thickness of a connecting rod.
ACinSC
Interesting , Thanks Don !
