wd45 cooling problems |
Post Reply | Page <123 |
hunter321
Silver Level Joined: 11 Jan 2021 Location: 52320 Points: 366 |
If the wd and wd45 have the same brake rod I could replace it easy
hunter321
If they are not the same where can I get them
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7970 |
same according to parts book
hunter321
All of the sudden the tractor won't start and it turns over very sluggish
Weak battery? Put it on a charger .
hunter321
The battery is fully charged
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4340 |
After a good battery, check the ground. I had intermittent trouble with one that had corrosion in the cable inside the factory insulation. Finally it pulled apart as I was cleaning the end again. The cable was on the mid 80's tractor when I got it 10+ years ago. Cable looked very good from the outside.
hunter321
I will clean all the connections.
So the bad ground caused the tractor to be sluggish and not start |
hunter321
I cleaned the connection but it still won't start. I have no idea what is wrong I just had it running
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77620 |
as mentioned, the two most common problems are the battery has not been charging and now needs to be charged up.... or the cables / battery clamps are corroded... Look inside the clamp on the battery cable.. Sometimes you get a black oxide coating that insulates the connection.. Need sand paper or wire brush to get it SHINNY... Look at the battery terminal also... wire brush till BRIGHT.
hunter321
ok i will check that when i get home.
hunter321
i cleaned the battery terminals and it helped with the sluggish turn over but i think the fuel system might be air locked
hunter321
is there a way to lubricate the starter and flywheel so it might work better
hunter321
I've tried everything you told me to and it still won't start for some reason
hunter321
It started and the pully plug blew out
Orange Level Access Joined: 12 Sep 2009 Points: 19473 |
So, put the belt pulley plug back in the hole and get a large 1/2" flatwasher to stick under one of the three bolts near the belt pulley hole to hold the plug so it cannot fall out again.
hunter321
Is there supposed to be hydraulic fluid behind the plug
hunter321
It leaked a lot of hydraulic fluid from the belt pulley plug
Is that bad that fluid came out of there |
On the left side of the tractor ahead of the battery box is a short dipstick. This is for the hydraulic pump. Refill it with hydraulic oil. This oil is what came out of the belt pulley hole.
hunter321
Ok so when the plug comes out it emptys the hydraulic pump reservoir
It doesn't "EMPTY" it. It loses a quart or two out of a 6 quart compartment. Refill until the dipstick says it's full.
hunter321
Ok I will.
So it is normal for it to have fluid in it |
YES. If you had a belt pulley, the oil is what lubricates the gears and bearings.
