WD45 hydraulic hose??? |
Thad in AR.
Orange Level Access Joined: 12 Sep 2009 Location: Arkansas Points: 9273 |
Posted: 27 Jan 2023 at 5:20am |
I blew a hose that goes to one of the lift cylinders.
Will a standard (made at NAPA) hose work? Wondering about the pressure? |
bikergreat1911
Bronze Level Joined: 22 Oct 2021 Location: new Bloomfield Points: 26 |
I'm was told you should be fine. That's were i was told to get mine once i start to redo it.
Youtube channel= rgs adventure
B26240
Orange Level Joined: 21 Nov 2009 Location: mn Points: 3860 |
1/4 inch hydraulic hose is what I used, fittings were different so correct police may object.
Orange Level Access Joined: 12 Sep 2009 Points: 19541 |
3000+ psi is the working pressure if the hydraulic pump is in good shape.
Thad in AR.
Thank you DR. Any guesses what standard hydraulic hoses are rated for? |
You tell me. Standard ?? There are one-wire and two-wire hoses. Each has its own pressure rating depending on hose diameter. I would EXPECT the hose to have writing on it giving the pressure specs. That's the way it is where I buy hoses...every hose is marked.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77824 |
smaller two wire hoses will have a WORK rating in the 6000 psi range... the BURST will be 3 -4 times that much. ... marked on the hose as Dr said.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8150 |
Was looking in parts book. Which hose do you need. Shows two different part numbers
Thad in AR.
The one that goes to the left(while sitting on the tractor) lift cylinder. |
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7995 |
Originals had a swivel end at least on left side so you could flip it fwd for cultivator use. If not using frt mnt cultivator could easily use a 90 and appropriate length hose. I had a swivel go to leaking so it got the bronze treatment.
Edited by SteveM C/IL - 27 Jan 2023 at 8:08am |
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3894 |
I took mine to the local JD shop they made me a replacement from 6000 psi hose they had the correct 90 deg swivel in stock. took about 20 minutes i went home and installed it been working great ever since. had both sides made at the same time.
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2854 |
I also had JD make mine new 10 years ago. They are same as what wa on it. 3/8's hose. I Make sure one side can spin. If both fitting are solid you'd have to spin the cylinder to install. Memory says the JD 1/2 hose was 3000PSI and 3/8's was 5000PSI. said on the hose.
wjohn
Orange Level Joined: 19 Jan 2010 Location: KS Points: 1804 |
Thad, last I had checked about a year ago the hoses were still available new from AGCO for about $40 each if you have a dealer not too far away. When I shopped around locally I couldn't find anyone that could make them for much better than that.
Clay
Orange Level Joined: 11 Sep 2009 Location: Udall, Kansas Points: 8802 |
A key thing to remember, when installing the hose, keep the STRIPE on the hose straight.
DO NOT TWIST the stripe!
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1219 |
I got mine from Agco a couple years ago . Probably may still have them. Perfect fit and price was fair. Around $100 dollars for both.
Sally123
Bronze Level Joined: 19 Jul 2023 Location: China Points: 1 |
Whether a standard hose from NAPA or another automotive parts retailer will work as a replacement for your blown hydraulic hose depends on several factors:
Pressure rating: Hydraulic systems operate under very high pressures. The replacement hose needs to have a pressure rating that is suitable for your specific hydraulic system. You should check the pressure rating of the original hose and ensure that the replacement hose can handle at least that much pressure. Over time, operating a hydraulic hose close to its maximum pressure rating can lead to premature failure. Size: The inner diameter (ID) and the length of the hose need to be correct for your application. A hose with the wrong ID may not allow enough hydraulic fluid to flow, affecting the performance of the system. A hose that is too long could add unnecessary volume to the system, while a hose that is too short may not fit properly or may be subjected to stress and strain that could cause it to fail prematurely. End fittings: The replacement hose must have end fittings that match those on the original hose. There are many different types of hydraulic hose fittings, so it's important to get ones that will connect properly to your hydraulic system. Compatibility with hydraulic fluid: Different hydraulic hoses are made from different materials, and not all materials are compatible with all types of hydraulic fluid. You need to ensure that the replacement hose is compatible with the type of hydraulic fluid you are using in your system. Given these considerations, it's quite possible that a standard hose from NAPA or another automotive parts retailer could work as a replacement. However, it's essential to check all of these factors to ensure that the replacement hose will function properly and safely in your hydraulic system. If you're not sure, it's best to consult with a professional or with the manufacturer of your hydraulic system to get a suitable replacement hose.
Edited by Sally123 - 19 Jul 2023 at 2:30am |
Thank you comrade. Please say hello to the Queen for me.
they are practicing with their Artificial Intelligence BOTS... Computer reads all the POSTS above, combines it all together, researches what all that means, and spits out the formulated answer..
Hope "it" reads my response !!
Ed (Ont)
Thad any hydraulic shop will make up a good hose for you. Just tell them the pressure you are working with. I'm sure you have had a new one on for months. Available from agco as well as I said earlier.
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3289 |
would you guys throw me off of here if i said what i thought about sally123 ?
John Phillis
Bronze Level Joined: 05 Jul 2023 Location: Burgettstown PA Points: 39 |
HAHAHAHAHAHAHA!!!!!!!! Now I want to hear this. The longer you wait to post it, the more it is going to fester, and then it will really be fun to read!
