7gb track loader radiator |
Post Reply | Page 12> |
Larry O F
Bronze Level Joined: 19 Jul 2021 Location: Denver CO Points: 25 |
Posted: 13 Nov 2022 at 12:16pm |
I need a radiator for my 7gb track loader. Does anyone have any recommendations?
Larry
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29486 |
Will need to call radiator shops, see who can construct a core for you.
Larry O F
I have done that. It is very expensive.
Anything used will not be much better than already have. the Core for my 2005 KW was $1200 BY ITSELF, no tanks. If needs one need to spend the money or deal without.
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 1784 |
I had a Mack tractor recored and it was $1100.00 using the existing tanks. They are sure expensive but an old rotted core won't hold up too long.
Tubes are least of worries, not even how clean in and out, what becomes a problem is the fine fin structures between the tubes, those are heat sinks for the heat in the tubes and once degraded enough that radiator will no longer dissipate heat. A used radiator might last months or a few years until loses same viability.
Larry O F
Just got a quote for a radiator rebuild $3500. Way too much for me. Anybody have any ideas?
Larry
Codger
Post some photos, measurements, and row quantity. I can ask a guy I use but you'd have a bit of freight costs involved.
Larry O F
I will do that. The radiator is at the repair shop at present. I will go get it tomorrow. He told me the core alone was $2900.
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3734 |
I dont own a 7gb but would it be possible to retrofit a used radiator from a tractor using the 426 engine? 210,220. 7030 and up? may work for occasional use and many more available for salvage. just a thought. $3500 is getting near cost of a usable machine
Dimensions, mounting type, hose sizes are far different. These also cool the high heat from hydraulics so roughly three times volume of AG.
Larry O F
I can't post the picture as the file is too big. I will have to figure that out. The dimensions are as follows.
core size = 32 x 24 1/2 inches 4 3/4 inches thick. six rows of tubes radiator is 38 1/2 inches by 28 1/2 inches overall It mounts with 4 long bolts, two on each side going into the frame from the front of the radiator to the back into the frame of the tractor. Anyone that can advise me how to post the picture would be appreciated. It has one opening at the top left, as viewed from the engine side and another at the bottom right as viewed from the same side.
Codger
I usually transfer photos to my desktop computer and resize a copy there to upload to the site. Never have been one to use my phone directly as I like the high resolution photos there.
Larry O F
Not even for a G-b, that is a 7G series radiator, G-b had squared off tanks top and bottom, BOLTED to core, same size and mount configuration essentially as a 7G.
Page 78 Minnpar parts guide.
Larry O F
That is what I need a radiator for a 7gb track loader. This is the radiator I took of my 7gb track loader.
Larry O F
Just to clarify my machine is a 1972 Fiat Allis 7GB track loader.
Square Nose, Fiat Allis with six cylinder or Round hard nose? Square over a six cylinder is a 7G-b, Round hard Nose four cylinder is just a 7G.
Codger
That radiator is older than your machine and quite fragile from the looks of it. Soldered tanks too so kinda hard to adapt another used core to it. I'll pass the information and forward recommendations.
Mine was a 1974 24476 s/n
Had mine cleaned, both the Donor tractor and the one out of the original tractor, those are Soldered STEEL Tanks. Bad coolant or not keeping up with additives and internal corrosion will destroy on inside out.
This is a HD7G-b, Pedal Steer, No Brake assist, Fiat Allis on Square tank to rear, single upper roller and Square Hard Nose. 6 Cylinder and a better tractor.
Edited by DMiller - 03 Dec 2022 at 3:56pm |
Larry O F
This is my machine. It has a six cylinder 3500 allis turbo charged engine.
Codger
Would you PM me some close up photos of that core and the tank to core joining flanges?
Correct Radiator assembly is a Bolted Tank unit, Allis P/N 70675925. If could find a used one, that could get away with a replacement Core and reuse tanks. Every radiator shop around here wants NOTHING to do with Soldered Steel tank radiators.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4346 |
See if a combine radiator out of a Gleaner L with the 3500 engine is close to the size you can fit. Could some good ones in used combine parts yards. The 3500 was opinion in the M sidehill model so my have been in other Gleaner M too.
Larry O F
My tractor serial number is as follows 28815.My parts book shows the radiator to be part number 70667966 prior to SN 29390. After SN 29390 to be part number70675925. I don't know what the difference is between the two part numbers.
One is soldered tank, the other bolted. Both configured same dimensions one serviceable one not so much.
Point made, early G-b series used a lot of the earlier Plain G series parts, i fall back to you need to locate the later radiator. Mount and dimensions exact but can recore simpler as bolted. I noted radiator shops are currently dropping soldered tank repairs as cannot deal with the EPA rules regarding those. Can unbolt tanks to repair or block corroded tubes or bad solder joints to tubes minimizing lead and acids exposures.
Larry O F
Either type would be acceptable. Mine is soldered and because it tore the bottom loose from the core they could not repair it without blocking off a number of tubes. That would result in lost cooling.
