TS 5 hydraulic pump question |
doctorcorey
Orange Level Joined: 17 Jul 2011 Location: S. KC Missouri Points: 570 |
Posted: 28 Sep 2022 at 12:41am |
Discovered today that the pump on my 'new' HD6G is part numbered (2025G1B1) as being originally issued on a TS 5 . P/N 2996. I wonder if anyone here could tell me the specs for this pump or the TS5 hydraulic system, especially GPM and relief valve settings. On a side note, I also discovered that I have control valve assy. 26403, which I have not found a listing for as of yet. I discovered that the main relief valve is adjusted all the way in, never a good sign.
Semper Fi USMC 1958 HD6G, 1959 MF 203 loader, 1960 Case 420B Backhoe, MF 65 Tractor/Loader Diesel
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3735 |
From what i have read the 5s were about 35 gpm a little less than the 40gpm of the 6g. 6g relief is 1200-1400 psi. 5 should be similar
doctorcorey
CAL(KS)
you could pull the pump down and check the end cases, if they show wear you can have them milled or planed back flat but you cant do anything about the gear wear. i would hate to price a new pump capable of 40gpm. and i would say that pump pressure is way to low. its possible something is stuck in the relief or the spring is broken?
Edited by CAL(KS) - 28 Sep 2022 at 11:36am |
doctorcorey
CAL(KS)
i know the 6g had an early and a late style relief valve, but i believe the late style superceded so it was a replacement part also. but definitely get that squared away and check pressure before tearing into the pump
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41209 |
believe it was 37 GPM on the Hydreco pump and relief valve on the HD5G was 1200#
Yes pump wear can create a problem , I use to be able to drag RPM way down to almost stall with the loader at full cycle up leaving control in raise position lock Roll back on bucket also would slow engine if held on = 50 years of use without replacing pump seems to have effected it - but 50 years of use has effected me also = well add 28 more to that 50 |
doctorcorey
Lee Bradley
Bronze Level Joined: 13 Oct 2009 Location: Kingston, WA Points: 115 |
In the up position does the loader hold?
doctorcorey
Coke-in-MN
The bucket tilt power to move machine is limited by the leverage configuration of loader frame design . You should be able to lift machine with bucket in full tilt to unload position and down pressure to loader lift cylinders .
Stalling the bucket cylinders in the lift or dump is easily done as cylinder size and pressure is limited . |
