Wtb d17 2 way hydraulic valve control |
Post Reply | Page <12 |
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5637 |
Here's a write-up I did some time ago: |
Orange Level Access Joined: 12 Sep 2009 Points: 19501 |
After doing a few of these over the years, I have never once used a pump larger than 10 GPM. This is based off of the wildly popular series 4 D-17 which was actually 12 GPM at full throttle and more GPM than a 50 HP tractor usually needed. Special projects may be different, but if a series 4 was ALWAYS plenty, most users will be happy doing nearly the same thing. I have also never seen the need for a separate oil tank. The existing sump can easily be tapped into to get oil from the tractor and return the same oil thru a filter. The sump capacity is more than adequate, especially when using 2-way cylinders. There is no oil overheating. There are no problems. There are no tanks to build to take up extra space.
Alex09(WI)
Orange Level Joined: 15 Mar 2012 Location: CECIL WI Points: 1698 |
We have front pump mounting kits for D14/15/17 available for purchase. You can use your own pump with SAE 'A' mounting or we have 9.5GPM or 14GPM bolt on pumps available too! |
www.awtractor.com
