WD45 Seat Bracket Bushing - Help Needed
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Seat Bracket Bushing - Help Needed
    Posted: 04 Oct 2010 at 12:42pm
I'm replacing - or trying to replace - the bushing at the front of the bracket which supports the pan seat on my WD45. Thus far I have not been able to budge the one that's in place. Here is a picture of the bracket - you can see the inner and outer shells separated by rubber.
I've thought about locating someone with a press - would that be workable? Or is there some trick to this that has eluded me thus far? Thanks for any suggestions!
Edited by Dave(inMA) - 04 Oct 2010 at 2:30pm
WC, CA, D14, WD45
Ken McGregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken McGregor Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 2:36pm
Try with a press...take out the inside shell first and then using a hacksaw, cut a groove in the side of the outer shell. Carefull application of a cold chisel will loosen and allow the outer shell(and rubber if it doesn't come out with the inner shell) to drop out. I note some rusting which won't make the last step any easier but it should work
BTW, we change knifehead bushings on a regular basis on my 469 NH Haybine....same technique.
regards,
Ken McGregor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 2:45pm
Ken, thanks for your suggestion! Sounds like a good approach....or perhaps I could drill out the inner shell. Yes, there's considerable rusting.....stuff surely makes things hard to move! I hope the new bushing goes in easier than the old one comes out!
WC, CA, D14, WD45
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 3:35pm
I used a torch. My bolt would not come out. So I cut the ends off with the torch. the rubber burned out the inner sleeve fell out and I cut the outer sleave out with the torch. That was after wasting a whole day trying to remove with ever other toll known to man.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 3:38pm
Dave, I know just what you mean! Glad to hear that it's not just me on whom the repair gods are not smiling. LOL
WC, CA, D14, WD45
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 3:56pm
Heat and PB blaster go my bolt out. However, I have not tried to remove the entire bushing yet. Was satisfied with my bolt remove achievement, so I put it aside for a while. Mine has lots of rust as well, so I will be trying the methods above. Good luck.
1954 WD45 NF "Iron Tater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 4:38pm
Jeff, I was able to drive the bolt out - went hard - that turned out to be the easy part! I've used PB Blaster and a couple of similar products, heat, BMFH.......none of those come close. I will try above methods and report back after I return from my first trip to the antique car/truck/tractor(?) flea market in Hershey, PA. Leaving tomorrow at 0-Dark Hundred.
WC, CA, D14, WD45
Kev Card View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kev Card Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2010 at 7:23pm
When i changed the bushing on mine i pushed the inside of the bushing out on the shop pres then got the rest out with a small cold chisel kept very sharp and a lot of light tapping with a small hammer Kev
RC,WC,2 C'S,WD45,185 ,618 LT
If it's orange and rusty Mary don't trust me
