Oil pressure
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Topic: Oil pressure
    Posted: 25 Jun 2022 at 6:12pm
  What is a ideal oil pressure reading for a WD45D that has a couple of thousand hours on a rebuilt engine using 15w 40 motor oil at operating tempt of 190 degrees?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 8:35pm
General rule of thumb is 10psi/1000rpm...Wink  If its on the r of the normal range, in the original AC guage, its OK...Thumbs Up
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 9:38pm
Check my post below. It is on a gasser tho. Mine went up to the "l" on normal with fresh 15-40 rotella and new filter.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 10:00pm
The diesel should run 50-60 psi @ full throttle.                  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2022 at 10:07pm
Was the oiling system on the diesel similar to gas or full pressure?
MACK View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2022 at 7:14am
Diesel was a full pressure system. Filters were a bypass filter.                MACK
