Brake Pins 😮‍💨
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2022 at 7:20pm
I was wondering if you got a torch and tried the heat.
If you have the replacement pins I would like to know the diameter and length.
What is the existing thread size of the internal hole?
INV3RSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2022 at 1:30pm
Im back!
Sorry guys been out with covid for a few days! Feel much better now.
I my mapp torch arrived a couple days ago. I had a go with it this afternoon and it does get the pin glowing! Yes!
I got the puller tight then heated it right up and tried to tighten the puller some more.. it was a bit looser the before heating so I’m presuming somethings happening! Hopefully! Il report back when Iv had a few more hot cold cycles.
Yes I’ll measure the pin for you tomorrow as well
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2022 at 3:57pm
When you get it HOT... SMACK it good with a hammer, even INWARD, then pull TIGHT and smake the puller... IMPACT always helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2022 at 5:16pm
Next time you get it hot, lay a bees wax candle against the pin.  The wax will wick its way in.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 1:04pm
Update!
I have 1 pin about 20mm out!
Is doesn’t seem like much but this is a huge achievement for the amount of effort I’m putting in 😂.
I got carried away and sheered off the threaded bar inside the pin but am ready with a nut and welder. I will hopefully be able to stick a weld through the nut on the the end of the sheered bar and wind it out. Then will repeat what I was doing before it sheered but with a little less muscle!
Now the pins moving I’m confident it will come free!
Anyway pin 1 of 2 is slowly being defeated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 4:12pm
instead of welding a nut on the end... you could stick a STUD in the hole and welded it... then you have a threaded rod to pull on with your puller and NUT.......... clean up the pin thru the BRAKE ACCESS HOLE . so there will be less resistance as that pulls into the outer PIN HOLE.
Edited by steve(ill) - 06 Jul 2022 at 4:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 5:13pm
Sorry about your covid, I know three people who died from it.
So  it traveled out 20mm? I would say the end should be nearly out of the blind hole.
So I think cutting out a section(s) of pin and pushing remainder through would work.
About removing the pin from a WD45. He ended up cutting the pin in stages and driving it back in,  so it dropped out that view port hole.  Welding on a nut did not work.
If the end piece didn't want to just drop out easy , then weld a length of All-thread to it and a nut&washer could pull it through. Leave enough length to allow this.
So how to cut? Can a reciprocating saw (Saws-All) fit through that hole? In that video he used cutting torch.
It's moving! You will get it.
There is a UK base Facebook page about the ED40.
I have been to Bristol, but not to far southwest of there. Countryside looks about the same?
Sanchez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sanchez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2022 at 11:12pm
While removing brake pins on my WD45 I found that the brake shoes will bind on the pin as the pins move outward. What worked best for me was once I had the pin out a bit a big pair of vice grips on the pin and rotate it back and fourth while prying out seemed to release the binding of the shoes. One other member said they had welded a piece of 1” flat bar stock to the pin and used it as wrench to rotate the pin back and fourth and work it out. It seemed like a good idea.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 6:28am
My experience with these pins has been that the trouble spot is on the outer end. Have not had a pin stuck in the inner hole. It's always the outer end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 7:08am
Woooooo!
After getting the threaded rod stuck in the pin.. and trying to weld a nut on ( unsuccessfully). i focused my attention on the other side to have a brake from welding.
And… success! It came out with heat force and a SDS drill on hammer mode!
Check out the pin 📍
Back to the other side again now I guess!
Wish me luck with pin 2 😂
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 7:37am
Wow that is a lot different from a WD45 pin.
Also doesn't look like illustration in the acgo parts book.
The left side of the pin is in the blind end?
I would say there is twice the engagement at that end vs. a WD45.
The brake shoes must be touching (bearing on) the two inner full size diameters areas?
Edited by BrianC - 07 Jul 2022 at 7:42am
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 8:52am
Pin 2 is is about 1/4 of the way out. It’s out the blind hole but is binding on the shoes despite feeling loose!
That’s enough tractor for one day, hopefully get it out tomorrow.
Iv attached a picture of my replacement pin, it’s second hand but not as worn as mine. Just to give you a idea what it’s supposed to look like 😊
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 8:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 9:08am
Reuben... do you guys use Anti Sieze or something similar on these parts ?  Good wire brushing and liberal coat of ANTI and you should be good for another 60 years !
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 9:28am
Cheers Steve, I certainly will be. Probably be my son who takes it apart next time!
The tractor was my dads, he had it for as long as I can remember and before. It’s never seen a oil change and almost rusted to nothing. I spent some time changing fluids replacing blown hyd hoses it preparation to sell.
But…
Iv become hooked, managed to find all the replacement parts secondhand ( what a mission, I had no idea the parts were so rare )
Allis is putting up a fight every time I try and work on her but I know itl be worth it!
Once I get this last pin rest of the way out the replacement shoes will be sent off for reline. In theory after that all that’s left is sand and spray panels, add a engine stop pull knob and she’ll be show ready! Oh and I need to make up a battery tray. All seems easy compared to these pins 😂 😆 😂
Thanks for the comments everyone, you ideas have all been helpful for me! 🙏
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 11:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 11:50am
Thanks Gatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 1:16pm
On closer look, 4” might not be sufficient length
Edited by Gatz in NE - 07 Jul 2022 at 1:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2022 at 3:41pm
The pin that he got out, is anyone doubting that it is original
design pin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2022 at 5:39am
I think it probably is
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2022 at 7:26am
INV3RSE,
I have been down this road too. Had to cut chunks out of center with a torch, let them fall out the bottom and then drive the pin inward and cut off another chunk. Not for the weak of heart for sure.
If you can do this job there is no reason you need to send the shoes for relining. You can do those standing on your head. Assuming you can get the pads and rivets for a supplier like Sandy Lake or others on this forum.
That tractor is testing you. But now you have the passion. Great projects to take our minds off the real world stuff. Family tractor too! We need some additional pictures!
Edited by Sugarmaker - 08 Jul 2022 at 7:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2022 at 9:51am
Cheers everyone.
I’ve spent all afternoon under the tractor again….
And
Success!
Final pin is removed! It doesn’t look bad as the other one but it put up more of a fight!
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2022 at 10:01am
Here’s some picture of the tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2022 at 6:08pm
That one pin is a work of art. Who would have know a simple
pin could change into a hydraulic spool.
Has anyone ever seen a WD/45 pin looking like that?
I am still trying to figure out how it got like that.
Rust and wear. I can see the rust in earlier pic, looks like an antique ships anchor
on display at the harbor. I cut up some rotted pallets, they had nails
rusted in interesting shapes. Seen fertilizer spreaders in bad shape.
Don't want to be a pest, but I wish I could see your replacement shoes nested together with that rusted pin placed. That would be my  "huh, look at that" moment.
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2022 at 6:43am
^^^ I was thinking the same thing!
That one pin had an interesting life.
