D12 rebuild |
Post Reply | Page <1 345 |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77840 |
hunter321
Silver Level Joined: 11 Jan 2021 Location: 52320 Points: 420 |
stupid thing to ask but i would have to remove the bucket and loader and cement front weight before attempting to pull the engine.
if i took the backhoe part of if i could i dont think i could ever get it back on Edited by hunter321 - 12 May 2023 at 2:02pm |
normally you roll the motor forward with the tires... I did a Backhoe tractor a few years ago... Transmission , rear end, tires, backhoe dont move. Block that solid..... I set bucket on the ground and blocked under the loader frame so it was stationary.. removed the radiator and everything around it... pulled the motor forward 3 inches and lifted out of the loader frame... but you would need a lift of some sort ..... have also seen pull the motor forward and drop to the ground and drag out from under the loader frame.. if you have room.
This is a CASE 530 under an 8 ft awning... I disconnect the front axle / tires/ etc and rolled forward a foot toward the bucket.. Pulled the motor and dropped it out the bottom.. just plenty or cribbing under the loader frame and transmission area.
