B Hubs |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6358 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Sep 2010 at 10:36am |
Are all B hubs the same?
Mine are 5 bolt but need to make sure they didn't change something along the line.
Charlie
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
All 5 bolt hubs might be the same, I don't have part numbers to confirm that. All B hubs are not the same. I'm not sure what the 37 had but, in 38 the hub was part of the wheel casting and a rim was bolted to the wheel. In 39 there was a 6 hole hub with the rim riveted to the hub. This probably doesn't answer your question.
I'm looking at a set of 5 bolts but since I can't physically put them in my hands I was just checking to see of they are the same.
Charlie
George Davenport ![]() Silver Level ![]() ![]() Joined: 20 Sep 2009 Location: Trenton NC Points: 127 |
My 52 B has 5 holes and an earlier 49 B has 5 holes.
Ken in Texas ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
All B-C-CA 5 bolt hubs will interchange. Bs after B-26524 were 5 bolt style hubs. I have noticed some 5 bolt hubs having subtle external casting differences.
Some of the early 5 bolt B hubs had grease fittings. Maybe it was only those used on the early IBs. ???
