HD6 locked in 3rd gear |
Joe Goodwill
Bronze Level Access Joined: 12 Sep 2009 Location: Souris Manitoba Points: 83 |
Posted: 29 Oct 2021 at 10:58am |
I have our HD6 and blew a shift it is locked in third I believe and shifter is out of place somehow. Can I pop the top off or is this a big project?
Thanks in advance. |
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3735 |
They are pretty simple. remove the two bolts that the shifter pivots on and pull the shift lever out of the top. then you can see the shift rails and have a look. likely you just came out of the gates because its worn. put in neutral with a bar and check pivots for wear. you can build up with a welder and/or make new pivot bolts then reinstall
Edited by CAL(KS) - 29 Oct 2021 at 11:13am |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41211 |
common problem on the shift tower being worn
couple things need to be fixed the bolts into the round tube in yoke wear as does the tube roll pin through yoke wears and gets sloppy and shift ball at end of yoke slips by shift rails
ball end wears on both flat side and round ball end and slides between shifting rails All this is easily fixed IF you have access to welder and a lathe |
Joe Goodwill
Thanks for the replies! Came apart repositioned the shifter and spent the afternoon clearing trees on fence line. Sweet machine for 60+ years old.
