D17 distributor oil reservoir
Steve A H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A H Quote  Post ReplyReply Direct Link To This Post Topic: D17 distributor oil reservoir
    Posted: 24 Sep 2021 at 9:57am
I have the D17 with the distributor at the back of the power steering pump/governor assembly.
I've done several searches and can not find an answer to my problem.
I've also  researched the Operators Instructions and Shop manuals for the D17 and can not find any reference to this.
Does the reservoir below the distributor mount where the distributor gear meshes with the gear on the pump shaft hold it's own supply of oil? How much oil do I need to add to this reservoir?
Thanks.
Steve A H
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2021 at 7:56pm
Half way up on lower shaft.                     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A H Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2021 at 3:57am
Thanks, Mack.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2021 at 9:08am
On Page 9 of my "Operating Instructions Manual" it says this:
DISTRIBUTER DRIVE HOUSING
Power Steering) - Check and fill within
 1-5/8" from top of housing with SAE 20W
oil. Check every 300 hours of operation.
That is exactly how it is written in the manual.
When I first got my D-17, I thought they were
somehow referring to the power steering but what
they really mean is tractors with power steering.
Had me confused for a moment.
The same basic info can be found on page 30 of the
Service Manual under the Gasoline section.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2021 at 4:54pm
if you have a tachometer, you may find the oil leaks out of the tachometer drive. If you don't want to repair that (might be parts unobtainable) oil leak, pump a good amount of gun grease into that cavity. Those gears cannot be dry. They need something for lubrication.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 6:04pm
Thanks, Brian for the location of the information.
I must have a different operators instructions manual than you.
There is no "Distributor Drive Housing" section on page 9 or anywhere in mine.
My "power Steering" section, (#3), says...
Front support is oil sump - capacity 4 -1/2 quarts. Keep filled to top of segment gear with sae 20 W.
All the photos of the tractor in the manual show the power steering pump/governor/distributor drive.
Never the less, thanks for the reference. I appreciate you taking the time to help me out.
Steve A H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A H Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 6:15pm
Well, DrAllis,
I don't have any leaks out the drive, but my tachometer cable sure is leaky! I overfilled the reservoir and the oil is "worming" it's way up the cable towards the tachometer and finding several spots to drip out of! I'm hoping it stops when the the reservoir gets to the proper level.
The grease packing would certainly fix this as well. I need a new Tachometer so will replace the cable.
Thanks for your help with this.
Steve A H
Rusty Allis View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2021 at 11:11pm
stupid question
is this on all D17s?
i have a series IV and i don't recall seeing that info when i went thru the machine last year
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 6:26am
Series 3 and 4 have belt driven power steering pumps and this does not apply. Only when the tractor has power steering and there isn't a belt driven pump is this an issue.  What usually happens is some of the parts wear out and you have what is going on here.....oil running out of the cavity thru the tachometer cable. Quick fix is pack the cavity in gun grease. Anything is better that a dry cavity with dry gears.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rusty Allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2021 at 12:20pm
thanks Doc. i wasn't sure if i missed something
