block of babbit ? |
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21487 |
Posted: 15 Sep 2021 at 3:47pm |
OK, clearing up a bit, and found a grey heavy block. I 'think' it's a cast block of 'babbit' material, kinda says that on the casting. silly question #1, is it of any value ? #2, anyone know WHERE I put it ? went to ake a picture and can't find the silly thing,sigh..... it's about 2 by 3 by 6 , grey.... dbl sigh...... Jay
dee_veloper
Orange Level Joined: 12 Apr 2021 Location: USA Points: 1168 |
Another senior moment....
Don't confuse my personality with my attitude.
My personality is who I am. My attitude depends on who you are. |
Dusty MI
It's on the shelf where the camera was.
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9660 |
dream about it tonight and then go there a pick it up tomorrow |
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50557 |
Babbit has value, If you are looking to buy, Almost $30/lb...
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 6658 |
Is it known by a different name? I’ve never heard of it.
Randy WI
Orange Level Access Joined: 22 Jan 2014 Location: Ogema, WI Points: 758 |
One thing you can be sure of you will find it in the last place you look. Keep on looking. Randy
There are a wide variety of recipes for Babbit, but its basically largely lead, with some tin added for gall resistance... Used to be used commonly, now its more or less a lost art, nowadays everything runs at higher speeds, and is better balanced... Here's a video... |
JW in MO
Orange Level Joined: 16 Feb 2010 Location: South KC Area Points: 2595 |
Steam guys hoard the stuff and are always looking for it. They are having a steam class every spring at our club to teach beginners to pro refresher classes. I asked the ring leader if he was going to have a class on pouring babbit and his reply was, "Pouring babbit is like hooking up a trailer, best done when nobody is watching."
DaveKamp
Orange Level Access Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5639 |
Many people don't realize that modern bearing inserts are coated in babbit... but that a poured babbit bearing, by virtue of how it is done, will result in closer fitment ability than any modern insert can establish. An excellent example scenario, is when a crank journal has a groove or dip worn in it... no need to grind it to make it totally flat, as long as it's round, just pour babbit around it, then disassemble, and cut in the oil grooves, reassemble, and run it!
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 619 |
I spent most of my working career as a sawfiler in sawmills and have poured literally many tons of babbit on saw guides for circular saws.
Most of that was lead-based babbit, but in recent years was switched to what we called 'nickel' babbit that is mostly tin with some antimony and a bit of copper. This stuff is somewhat harder than the traditional lead-based alloy. Babbit saw guides in gang edgers lead a very short life due to the large amount of sawdust inherent in the operation. Saw guides are changed out frequently, typically after a few days of run time; the babbit is then melted down, re-poured, and cut to size on a special milling machine. |
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3292 |
i need to find someone to pour or re do two early john deere rods here very soon
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5173 |
Link to a Video 'Pouring a Babbitt Rod Bearing for a Model A Ford Engine' G https://www.youtube.com/watch?v=JBL0Y3_yQ7I |
