D17 IV rear tire fluid |
Ryan Renko
Orange Level Joined: 12 Sep 2009 Location: Edwardsville, I Points: 2315 |
Posted: 11 Sep 2021 at 9:37pm |
I am in the process of getting my rear tires taken off so I can get everything sandblasted and repainted. I really don't want to put calcium back in but do want the added weight and am considering options like beets juice. What is the guesstimate on how many gallons I would need to bring to the recommended level? Thanks, Ryan
55allis
Orange Level Joined: 30 Jun 2020 Location: Southwest IA Points: 549 |
I recommend beet juice (Rim Guard), it’s a bit cheaper then wheel weights but won’t rust your nice rim.
Here’s a link to the rim guard place. https://www.rimguardsolutions.com/beet-juice-is-better/tire-fill-chart/ Edited by 55allis - 11 Sep 2021 at 10:48pm |
K bockting
Bronze Level Joined: 18 Oct 2012 Location: MO Points: 135 |
I use methanol in all my tires.
1/3 methanol 2/3 water. 16.9/28 probly 60-70 gal close to full |
Orange Level Access Joined: 12 Sep 2009 Points: 19556 |
I recently removed calcium chloride fluid from some 16.9 x 28's and would call it 55 gallons in each tire, which at the strong 10 pound mixture would have been 550 lbs in each tire.
Ryan Renko
I would like to also find some pie weights but they are like hen's teeth. Anyone roughly know what the beet juice costs per gallon? Just curious on what 100 gallons might cost me.🤔
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4427 |
For the price of the beet juice and then again after you have a flat and lose all of the first fill You can buy cast iron that will never rust your rims or go down the gully when you have a flat. The cast iron doesn't have to be the AC pie weights just a weight that fits the bolt pattern. The F&H weight are plentiful and cheap if they aren't painter JD yellow.
That's how I get rid of the F&H weights, paint them yellow and put them on CraigsList for $350 a pair. They sell as fast as I can paint them. Rusty ones won't bring scrap price.
55allis
A couple years ago it was $3.50 a gallon pumped around here in Iowa. Edited by 55allis - 12 Sep 2021 at 10:08pm |
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1223 |
I know some tire guys here. They all say to stay away from beet juice. Stick to calcium. Replace valve cores if they start to seep. If not buy two drums of windshield washer.
Brian Jasper co. Ia
When I googled how much fluid in a 16.9x28 I found several charts that said 73 gallons in each wheel. Either way, at 50 or 73 gallons per wheel adds up in a hurry at $3.50 per gallon...
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4412 |
I saw a post on here, a few years back, where someone said they change their valve assemblies yearly. The entire valve assembly costs about $5 each. That sounds like the easiest and cheapest solution to me.
PaulB
Why bother with anything that will potentially rot out the rims. With the saltwater it is never a question of "IF" but "WHEN". As I said above one flat and all that is wasted. Unless you are doing constant loader or tillage work. the need for all that added weight is only imaginary and the cast Iron weights can be removed and pile in a corner and put back on when it's really needed. If doing loader work a 55 gallon barrel of concrete on the rear hitch is just the ticket and actually better at a counter balance that tire weight.
Engineering is usually ALWAYS a compromise. To get one thing, you might have to give up something else. Tire fluid of any type is out of sight and gives the lowest center of gravity. It also doesn't ever stick out to catch a fence post. They ride better than a tire with just air because they don't bounce as much. Calcium Chloride is the heaviest per gallon at 10 lbs. RV antifreeze or used antifreeze is relatively cheap and still gets the job done without chance of rim cancer years later, but weighs less than 10 lbs. There will always be the naysayers both ways. A simple replacement of the valve stem every 5 years is a small maintenance price to pay. Just like changing engine oil every 100 hrs, it's just something that needs to be done. If you don't, well there will be trouble down the road.
Edited by DrAllis - 16 Sep 2021 at 9:49am |
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8013 |
I try to change cores every 2 years. That seems to be about the time they start to leak.
Ryan Renko
I was quoted a price today of $550 to load my tires with Rim Gaurd. Obviously this isn't a working tractor so I will just keep searching for pie weights. Ryan
Pie weights may not be any cheaper and will not yield as much weight as fluid, based on $550 for "full" or recommended fluid fill.
Edited by DrAllis - 19 Sep 2021 at 6:58am |
WF owner
I believe pie weights are around 75 lbs. each for a total of about 300 lbs. per wheel verses about 700 lbs. per wheel for calcium.
