How critical are good accelerator rollers.
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Topic: How critical are good accelerator rollers.
    Posted: 05 Sep 2021 at 4:44pm
Probably a dumb question because I know these are the heart and sole of a Gleaner Rotary combine but are they are critical in corn as other crops I don’t mind replacing them but I just got this N7 and the ones on it are wore completely out down to the metal know that if a pencil will fit they are wore out but I can stick my hand in between them. it will probably only see 50 acres through just to test it out I know nothing about the machine and I’m wanting to see what I’ll do before I spend a bunch of money on it.
Edited by AllisandGleaner - 05 Sep 2021 at 4:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2021 at 7:31pm
If you cannot clean up the sample in the tank and/or have cleaning shoe losses that you can't seem to fix, those rubber rolls are probably the issue.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2021 at 1:44am
If the price is the main factor, see if you  can dig through the dumpster of your local Gleaner dealer, or ask any locals that run Gleaners.
Many sets are changed as part of a preventive maintenance program when they know they wont make it through another year of hundreds to thousands of acres, but they are still good enough for a hundred or two acres.
It sounds like yours are completely shot. I'd expect shoe loss from the slobbering, so i'd try to replace them with a better set.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
