Allis B with Mag |
Andrus
Bronze Level Joined: 26 Jul 2021 Location: Western Mass Points: 10 |
Posted: 26 Jul 2021 at 5:27pm |
I'm fixing up a 1940 Allis B with a magneto and a starter and generator, but no lights. I don't want to use the three position switch in the control box as I can't get one with original looking knob, and no lights. I have a cut out on the generator and a standard 6 volt battery with positive ground. I have a wire from the starter to the ammeter and from the other side of the ammeter to the cut out on the Batt terminal. Then what? A wire from the cut out Gen terminal to the armature terminal on the generator? But what about the field terminal? Should that be wired to a resistor? What amperage resistor? And from the resistor to where? Thanks, I'm pretty confused about how to do this.
acd17toy
Orange Level Access Joined: 11 Sep 2009 Location: USA Points: 684 |
If you do not have a owners manual get one, as it should have the wiring diagram in it.
Andrus
I have the owner manual as well as the shop manual and the parts manual. They are not helpful as they all assume you have lights and the three position switch. I'm trying to avoid having the ugly three position switches that are the only ones available.
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77236 |
The light switch either goes thru a resistor ( to charge at 2 amps), or straight to GROUND ( to charge at 8 amps)... You could use a toggle switch to ground and just turn on for 10 minutes every time you run it........... or you could use a resistor in line and have a constant 2 amp charge like a trickle charger.... Im not sure what the resistor OHMS is... maybe Steve B&B will chip in here..... (I think it is something low like 5- 10 ohms)
Andrus
This is great! That's exactly what I needed to know. Thanks very much Steve. You da man.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11503 |
I'm probably the only knucklehead on the planet that still makes parts and rebuilds the 3 position switches if you can't find an original. The aftermarket one that all the venders are selling are junk. They also do not fit in a lot of the tight instrument boxes, and usually ground themselves out smokin' the wiring system. Visit our website, go into the switch category and check out our rebuilt switches if interested. We also have the new resistors that Steve posted.... HTH
Steve@B&B bb-customcircuits.com
Andrus
Hi Steve, I just ordered the stuff I need from your store. I'm glad you replied to my post. Your store looks like a really good resource, not just for Allis Chalmers but for my other tractors too.
If it has ANYTHING to do with wires/ electrical / mags/ distributors for ANYTHING.. Steve is "THE GUY".
Steve in NJ
Thank you for the order Andrus'! We appreciate that. I'll have to build you a "fresh" 3 position switch. I didn't realize that JoAnna sold the two I had ready to roll. Man, I gotta' keep an eyeball on that lady of mine, she's quick! No problem though. We have the technology. LOL! Steve@B&B
