HD6-B Tensioner Screw Thread Size |
jwoods
Bronze Level Joined: 12 Jan 2014 Location: Oakwood, OH Points: 19 |
Posted: 25 Jul 2021 at 1:36pm |
Hello All,
Had to cut out the old threaded tensioner (22-3/4 length), heat the yoke and extract the threaded portion. Two options so far: 1: Find a boneyard donor 2: Find the correct thread/pitch bolt and weld onto the remaining hex stem. Looks like 1-5/8 x 5.5 pitch, but figured would throw it out here; also if anyone has a source for either. Thanks, -Joe
AC Mel
Orange Level Access Joined: 23 Jan 2010 Location: N.Ca. Points: 1099 |
We might have what you need....we're a long ways away...California. Hector...(gemdozer)...will probably be able to help you. He's got access to a lot of those parts. He'll see the post.
jwoods
THanks Mel, and...you are correct.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41160 |
I turned a length of stock to thread - then welded it to the end of the hex part on a HD5B - the lock collar was bad though so had to find a nut to fit end of new turned thread .
If I were to do it again I would find a hydraulic ram and make it a grease type adjuster . |
jwoods
Thanks All,
I was able to find a used replacement screw.
