Trailer questions |
Post Reply | Page <12 |
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21451 |
Had a quick look, and according to Edmunds, that JEEP can tow 5000#, so it'll pull a B on a small tandem trailer no problem,especially with a V8. I KNOW a 73 CJ-5 could tow a carhauler with 67 stang on it. Yeah not exactly quick off the light but did the job. Have a custom trailer built ,narrower and shorter will shave 100s of pounds of unecessary weight off.
Orange Level Access Joined: 12 Sep 2009 Points: 19475 |
And, a proper 2-wheel trailer COULD work and be safe. The problem (most of the time) is people don't know how to properly load a 2-wheel trailer. Once properly loaded, the tie down chains or the floor or something has to be marked so it gets loaded exactly the same every single time. Six inches of incorrectness on positioning can be a disaster.
Rod in MN
Silver Level Joined: 16 Sep 2009 Location: Rice MN Points: 290 |
Hi, I would not get a single axle trailer and tandem axle will be a smoother ride. Get brakes on both axles so if you would cross state lines you would be all ok with laws. Get a rub rail and stake pockets for chain tie down. And storage box for chains and chain binders with the sealed cover and with a way to lock it up. Get a 7 pin electric plug in
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 602 |
I'm with you there; short wheelbase lightweight towing rig with ample horsepower plus heavy trailer is a a good way for bad things to happen. Definitely use a weight equalizer hitch with stabilizer bars on that thing. |
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11388 |
Good grief guys, he's towing a 2100 pound tractor to the fair. I've seen plenty of Jeep Grand Cherokees towing campers and loaded with gear surely totaling more than that. Edited by Tbone95 - 29 Jul 2021 at 12:58pm |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77629 |
YEA... i dont think he is going to buy a $50,000 truck and trailer to pull a $1000. tractor to the show... See lots of Crossovers and Jeeps pulling campers and pop-ups.. Not a problem........... 2000# trailer and 2000# tractor will do just fine.. He is not going cross country.
Rod in MN
Hi. You will have to look if you have a 4 pin or a 7 pin or both for trailer lights. The Jeep may have a wire tucked back in to the main wiring going to the rear. And it may be the same way under the hood by the fuse box. You would have to do some checking on the wiring. You may have to put a beak controller in the jeep on the low dash
There my be a wiring harness you can buy it a parts store that will plug in to your truck and the brake controller First drive around with a empty trailer and get the fell off just the trailer, then load up tractor and drive around with that and step on the brakes see if you can feel the trailer brakes working if not turn up the brake controller and check again |
mdm1
Orange Level Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2592 |
When I bought my trailer they said to have the rear of my truck squat a couple of inches when loaded. Also when you set your trailer brakes with your controller do it on gravel so you don't get a flat spot on the tires. I also have a rub rail and bobcat ramps on mine. Like has been said-it's not the towing but the stopping. Buy the most and best trailer you can afford. Sounded like an easy deal when you first asked I am sure. Good luck.
TMiller/NC
Orange Level Access Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1774 |
Thanks(1)
I have an 18 foot with 2 3500 lb axles that I haul a B and golf cart, tow with a 2016 V6 Chevy Colorado Z71, no problems going or stopping. Common sense and be careful.
Thanks(1)
You'll almost always need a 7 pin connector to get brakes and backup lights. JEEP is prewired for brake controller(everything since mid90s is...). Not many trailers have backup lights but the connection is there, so spend $20 and add them. Also if you get the chance ,upgrade to BOTH axles having brakes.Maybe only $100-$200 extra. Trying to stop 5000# tail wagger in the rain,going downhill isn't 'fun'.
JSHIVERS
Bronze Level Joined: 24 Jun 2021 Location: Bloomington,IN Points: 54 |
Thank you to everyone so far. I'm getting a lot of good ideas on what to look for
and what to watch out for. I know way more about trailers now than I ever expected to. Appreciate all the comments. Keep them coming.
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4635 |
Thanks(1)
Getting the B loaded correctly is also key. Get a 2axle trailer as I and others have said. After its hooked up correctly to your trailer hitch and locked down, Pull the B up on the trailer and watch your vehicle as you pull forward. Somewhere centered over the axles, your Jeep should be squatting some but not too much or it will be too light in the front end, but not too much to the rear of the trailer or it will actually make the rear of the Jeep rise causing an undesirable light rear end and lose of braking and traction. Either condition is dangerous. You will find a happy medium after loading several times and towing with it. Only a few inches either way makes a world of difference. Too low of a rear end squat will cause swaying due to front end not having enough weight to control steering and it can cause you to jack knife the trailer. Too high of rear end can also cause loss of control and hopping especially under braking. I have had to rearrange my tractor on the trailer before once under way and notice I have a problem. Once you have a few pulls under your belt it will become second nature to you how your trailer and vehicle respond. SUV’s, short bed trucks, long bed trucks all tow differently. So, 2 axle trailer, brakes on each axle, brake controller in your Jeep, use common sense, take your time, and arrive safely.
No problem Edited by AC720Man - 30 Jul 2021 at 8:27pm |
