12 HP Kohler Foot pounds |
GARY(OH/IN)
Orange Level Joined: 19 May 2010 Location: Findlay,Ohio Points: 917 |
Posted: 03 Jul 2021 at 12:26pm |
My Simplicity 7112 engine has passed on. I'm looking at replacing with a Predator 8 or 13 HP engine. Wondering how many foot pounds of torque the Kohler 12 HP cast iron engine serial number 10182359 had. It will only be used for mowing. Any help is appreciated.
wjohn
Orange Level Joined: 19 Jan 2010 Location: KS Points: 1798 |
When I looked before it's always had to find numbers on these. There are a few charts that were probably from a Kohler sales brochure floating around. This is the best one I can find quickly: https://www.ihcubcadet.com/attachments/264487-jpg.84721/
Some discussion on it here: https://www.ihcubcadet.com/threads/archive-through-november-06-2013.4620/ Looks like around 22 ft-lbs for a K301?
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77708 |
HP = TORQUE x RPM / 5252
TORQUE = HP x 5252 / RPM Torque = 12 x 5252 / 3000 = 21 Ft pounds. it all depends on what the RPM rated is for TORQUE.. May not be the same RPM as max HP.
GARY(OH/IN)
Thanks to both of you for your info.
GARY(OH/IN)
Thanks to both of you for your input.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21463 |
if it burned as much oil as the one in my LGT125 did, probably not even close to 21 ftpds.....I replaced a 12HP Tecumseh (Sear St12) with a 9HP 'off shore Honda clone', and it has tons of power. Check shaft sizes ! somehwere in the HP range they change from 7/8 to 1". most snowblow engines are 7/8"...arrrgh.... |
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41195 |
Had a Kohler K341 - 16 HP on my New Holland S16 - replaced it with a Tecumseh 16 Hp which seemed to have more torque - ran that for about 8 years until it seized -
Replaced it with a 18 HP Honda engine and still runs good . The Predator engine is the Chinese knock off of Honda - but seem good as put a 6 HP on my tiller and has worked fine . On compactor replaced the Wisconsin Robbin engine with a Tecumseh but went through 2 engines as would not stand up to vibrations - Went with a Honda and it has run for over 6 years of use with no problems |
