Armrest Hardware |
Tad Wicks
Orange Level Joined: 27 Mar 2011 Location: Shandon, CA Points: 2160 |
Posted: 18 Apr 2021 at 2:02pm |
Anybody have pictures of the armrest hardware used in the 9 11 15?
Lazyts
Orange Level Joined: 05 Feb 2012 Location: Manitoba Points: 627 |
Do you mean the nuts inside the armrest? If so, they are a "pronged tee nut" 3/8-16 x 7/16" available from building supply stores.
Tad Wicks
Thanks for the info, but I was looking for pictures of the goodies that lock the armrest to the battery box, the rear clips and the split tongue that goes over the bolt in the front. The armrests I bought years ago were not correct at all, the wood is rotting but the fabric is still very good, so I pulled the staples and removed the old wood and figured while I had it down I would put the correct hardware, the armrests like to try and get away on the steep hillsides
Lazyts
Right, sorry- I was thinking the later models. I have built what you are talking about too, years ago. Here's what I did:
-Cut a piece of 16 guage steel the same size as the armrest plywood- drill holes in it to attach it to the plywood. (If you're starting from scratch- use the nuts I mentioned, or if the armrest is intact, use screws) -weld three tabs on the back end, one to fit vertically into the notch in the rear of the battery box, and two horizontally (one on each side) to prevent the cover from popping up. -weld the forked piece at the front, to slide behind the 1/2" bolt and approximately 1" square block at the front of the box, which is then tightened to lock it all in place.
Tad Wicks
Thanks, thats's what I want to do, I was just hoping somebody had a quick picture of the factory hardware. Tad
AC Mel
Orange Level Access Joined: 23 Jan 2010 Location: N.Ca. Points: 1099 |
Tad.....we did some several years ago for some of the restored tractors. These would be the original brackets. The original had metal with wood...we just went to the plywood.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4366 |
Ok we have a better idea of what your looking for Tad. I just cannot get my brain around doing pictures. Was about to say my cous Rod is close to you now, but I am not sure if he has any HD 9's over your way, because it seem he has been using a D6 out your way.
Mel came through with nice pictures. But the factor arm rests all had a piece of steel with the wood Mel has on top of that. Held together with the special nuts Lazyts was talking about. Mel also did not show the nut used to tighten the front down, not that I have ever found one that had been tight. The nut is a square piece of 1/4 inch about 1.5 x 1.5 with threads taped in the center. With better plywood Mel's way looks real good to me. Did you put that together your self, I have been doing my own with staples or roofing nails for 40 years. But I always use a lighter color than black. I may not be the brightest, but I only sit on a black one once on a 100 degree day an we get those often in summer.
Tad Wicks
Thanks Guys ever so much, Mel, that is just what I needed. I would guess that the stock is 1/4 x 1 1/4, just narrow enough to slide into the notch in the back.
Whats the matter Ray you don't like solar seat heaters? in the summer time you can always resort to the old standby, A flake of hay double wrapped in a gunny sack and they are adjustable, want to sit higher grab a thicker flake and you won't sweat against the vinyl works pretty good as long as there are no goat heads in the hay
Mel, no luck on the little guy yet, will keep trying |
AC Mel
OK.... Here's a couple of pictures of the brackets Ray is talking about Tad....Yes I keep watching for the post when you get your hands on it.
