Wanted to introduce myself and see what I bought |
Post Reply | Page 12> |
CMNrallye79
Bronze Level Joined: 20 Jan 2021 Location: Cleveland, OK Points: 15 |
Posted: 20 Jan 2021 at 9:05am |
Good morning,
So I became the proud owner of an Allis Chalmers tractor Monday evening. I love rebuilding things most usually they are in the form of international scouts. I grew up with several Allis Chalmers combines model E but have never owned or operated an Allis tractor. After getting it to the house I think it is a not a pure model. I bought it as a B because of the front end, after looking it over and finding the tractor number it appears to be a C (C18913). So I am now looking for info to find out how many pieces are not from the original tractor any thing you all could pass along would be greatly appreciated. Thank you, Mark
KMAG
Orange Level Access Joined: 26 May 2020 Location: Elizabethtown, Points: 654 |
Post some pictures of it. The C is like the red-haired step-son of the AC world. They are great tractors -nfe or wfe.
We'd like to see your new unit and know your plans for it - show/work/re-sell. Scouts are nice, but rusty. I swap parts off them (springs and D44 parts) for my CJ7 and M37. Edited by KMAG - 20 Jan 2021 at 9:16am |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77868 |
the B and C use many of the same parts... radiator, motor, hook, gas tank, transmission, differential, hydraulics, tires and rims.......... what is different is the B is a ONE ROW tractor and the C is a TWO ROW tractor... The final drive cases on the C are 6 inches WIDER than the B... on the front end, the B is always a wide front end.. Steering box below the gas tank has an arm pointing DOWN and a drag link to the left front tire kingpin.... the C has the steering box under the tank with the arm UP.. drag link goes to a SECOND steering box under the radiator.. arm sticks out the side of the radiator shroud. C can be narrow front, or wide front end.
CMNrallye79
CMNrallye79
the front end and steering are all from a B.... The back end is hard to tell, cant see the WIDTH.. The 5 bolt wheel is standard on a C and they have a big DISH to them..That looks like what you have............. Probably someone took the transmission and rear end off a C and connected to the engine and front axle of a B.
I cant see clearly on the radiator cover... Is there an opening at the bottom left side where a C steering rod might have been ?
CMNrallye79
It is possible someone took the front axle and steering box of a B and just put on the C tractor........... you would have a cutout on the left lower corner of the radiator cover.......... From the pictures, the WIDTH of the tractor appears much bigger in the BACK than the front end.
CMNrallye79
CMNrallye79
CMNrallye79
What I want to do with it is a great question, I have a Massey 35 Diesel Deluxe and my grandfather's 1951 8n, I use both for various tasks. My original thoughts for the Allis were a trailer queen/ parade wagon puller. In discovering that it's not pure I honestly don't know, I have a line on an original plow and belly sickle more for it. I also have a line on a parts B that I could put the motor with to make it a full B. I like the C wide front tractor so I may keep my eyes out for one and go that direction, so at this time I am in a fact finding mission. At the bare minimum I will return to good mechanical condition as I hate to see any of them in disrepair.
C in Concord
Bronze Level Joined: 26 Sep 2019 Location: Concord, WI Points: 109 |
Welcome! If you can pull the engine # from the bellhousing mount (left hand side from the driver position, should start with BE or CE), I/we can tell you what year it is. If it was also from the 1942-1943 timeframe (your C18913 serial # equates to a 1943), it's probably the engine it came with and someone did just a narrow to B wide-front swap.
Yours looks like a better job. Only thing that doesn't match the B wide-front is your grill, it is from the C, has the large round cutout underneath for the narrow front. Other than that, looks pretty complete and usable, just needs a battery box and headlights (if needed). The rockshaft is a nice find too. With a little creativity, they can do a lot.
Edited by C in Concord - 20 Jan 2021 at 11:47am |
Leave things better than you found them.
1941 Model C (restored 2020) |
Bill Long
Orange Level Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
First, let me welcome you to the Unofficial Allis Chalmers Forum. As you can see there is a wealth of information available from some of the best sources.
You have an "interesting" tractor. Looks to be a C with a B front. As stated above the B and C are basically the same powered tractor with a different configuration for a one row or two row tractor. As stated above your tractor appears to be a C with a B wide front. Again, welcome to the forum. We look forward to seeing additional information on this unusual tractor. Good Luck! Bill Long
GreenOrange
Orange Level Joined: 11 Sep 2009 Location: Wisconsin Points: 827 |
Welcome to the forum! It also looks like it was an original steel-wheel tractor too, which makes sense with the serial. It has the rear steel centers and tall air cleaner stack.
CMNrallye79
So the rockshaft is not a term I am familiar with. I assume it is the piece on the back of the tractor that acts kind of like the three point on my other tractors. What implements work with it?
Ky.Allis
Orange Level Joined: 31 Jan 2010 Location: Kentucky Points: 967 |
Hope it was free cause it's not worth much.
HD6GTOM
The wide front makes it a far nicer tractor than a narrow front. Congrats on your buy. It'll make you a nice addition to your fleet. You could find a pull type plow or a mounted plow made for the B/c tractors. They made a mounted mid mount mower for that. Grand dad had 1 on his C. He put a smaller pulley on his PTO shaft so the sickle ran a little faster. It made a nicer outfit to mow hay.
HD6GTOM
The wide front makes it a far nicer tractor than a narrow front. Congrats on your buy. It'll make you a nice addition to your fleet. You could find a pull type plow or a mounted plow made for the B/c tractors. They made a mounted mid mount mower for that. Grand dad had 1 on his C. He put a smaller pulley on his PTO shaft so the sickle ran a little faster. It made a nicer outfit to mow hay. FYI If I still owned my tire shop, front tires would cost you $37.42 each. That would be a mounted price. Tubes would be extra.
C in Concord
Correct. I'm a bit out of my depth on the implements, but single bottom plows seem to be the most common. Also seen different cultivators & back blades, not sure what all was modified to fit and what came from the factory. You can also use it as part of a three-point conversion. I welded an arm on mine as part of the lift mechanism for my front mounted snow plow. Possibilities are endless! The two hydraulic ram setup on yours is interesting. Appears your rockshaft is solid all the way across, so they are working in tandem, I assume off a single control. Most units I've seen with hydraulics have a single cylinder.
CMNrallye79
The engine number appears to be
CE189400 the last number could be a C it is not perfectly clear. Does that jive with it being the same age as the transmission? |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8151 |
welcome to forum
CMNrallye79
Thank you for the warm welcome and all the good information, it is truly appreciated!
the most common implement for the back, run by the "rock shaft" would be a single bottom plow..... below is a picture of a plow beam with the plow removed and a blade fabricated to fit the beam..
another common use of these tractors is to install a belly mower for cutting larger yards and field maintanance. |
john(MI)
Welcome to the Forum. A wealth of knowledge here, and we can use your input too. In the Barns, Shops . . . . . section, you can get answers and recommendations on about anything you can think of. It's too bad that you just got the tractor and you already have to take off a rear tire and turn it around. I hope they are not full of fluid!
C in Concord
The last digit is typically a "G". CE18940G is mid to late 1942. Most likely the original engine for your early '43.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11558 |
Welcome to the best darn AC forum on the planet! As the others mentioned, it looks like you have a C model with a B front end. Sometimes they get changed because of the way the owners property might have been a little hilly, where the wide front has much more stability on hilly property. Good luck with it! Looks like a great start!!
Steve@B&B bb-customcircuits.com
Roger Mn
Bronze Level Joined: 12 Sep 2009 Location: Preston Mn Points: 98 |
the two cylinders are used when a corn planter is mounted to tractor
CMNrallye79
This is the left side from the front.
CMNrallye79
CMNrallye79
Engine Number
