1946 C Cracked Block
bben486 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bben486 Quote  Post ReplyReply Direct Link To This Post Topic: 1946 C Cracked Block
    Posted: 19 Jan 2021 at 12:29am
Hello All,
After removing the head from my '46 C I saw a small crack at the top between # 2 and 3. Heard this is rather common and not something overly harmful? What are the best options for repair?
Thanks Again for the Help
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 4:29am
Very common on those engines, the head gasket will seal it up. I wouldn’t worry about it.   I think most of those blocks are cracked there. I know I’ve seen at least a dozen cracked between the top cylinders and it didn’t cause any problem.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 7:52pm
have a wc like that; filled the crack with JB weld an put it back together. been 9 years ago. still working fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2021 at 9:18pm
You are good to go.  Came across that when I did the engine on my D14 10 years ago.  No problems so far!
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2021 at 6:49am
Put some sealer on your head gasket and put it back together. Cracks at the top, between cylinders are very common.
