1946 C Cracked Block |
bben486
Bronze Level Joined: 16 Jan 2021 Location: CT Points: 7 |
Posted: 19 Jan 2021 at 12:29am |
Hello All, After removing the head from my '46 C I saw a small crack at the top between # 2 and 3. Heard this is rather common and not something overly harmful? What are the best options for repair? Thanks Again for the Help
DaveSB
Silver Level Joined: 04 Aug 2012 Location: mocksville, nc Points: 235 |
Very common on those engines, the head gasket will seal it up. I wouldn’t worry about it. I think most of those blocks are cracked there. I know I’ve seen at least a dozen cracked between the top cylinders and it didn’t cause any problem.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
dawntreader74
Orange Level Joined: 28 Oct 2013 Location: Manteno Points: 1758 |
have a wc like that; filled the crack with JB weld an put it back together. been 9 years ago. still working fine.
DSeries4
You are good to go. Came across that when I did the engine on my D14 10 years ago. No problems so far!
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4402 |
Put some sealer on your head gasket and put it back together. Cracks at the top, between cylinders are very common.
