wiring |
Post Reply | Page <1 111213 |
jvin248
Silver Level Joined: 17 Jan 2022 Location: Detroit Points: 268 |
In theory you should be able to drill it out since the replacement tube will have the correct critical ID passage size. Verify depth stop (I use a small block of wood as a stop not just masking tape for critical depth stop situations). .
hunter321
Silver Level Joined: 11 Jan 2021 Location: 52320 Points: 456 |
What grease do I use for the steering gear assembly
hunter321
i got all the jets out of the carburetor but the mount for the float broke what should i do
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77895 |
you can solder it back together........... or buy a new one.
hunter321
Would I have to drill out the old pins holding it to the carburetor
hunter321
The on off on switch I have has 3 terminals
hunter321
when i get the money i think i will take the carburetor to the tractor shop so they can fix the float bracket
hunter321
where can i buy the float bracket
hunter321
I am finally wiring up the fender lights but I can't figure out how to run the wire from the fender to the wiring box on the battery box
How were the original fender light wires ran |
