1949 Allis Chalmers WD project |
Post Reply | Page <123> |
IBWD MIke
Orange Level Joined: 08 Apr 2012 Location: Newton Ia. Points: 3458 |
I thought having CRS, cold rolled steel was a good thing. I keep a supply around here for repairs that pop up. Or did you mean Can't Remember S***? I'm guessing the later, seam to have plenty of that too!
55allis
Orange Level Joined: 30 Jun 2020 Location: Southwest IA Points: 548 |
I took the manifold off and broke a stud which luckily it just broke the threads on the end off.
I also got some Persian #1 paint and also Hardener/Catalyst for hardener from Van Syckle. |
55allis
Have it about ready to paint but still haven’t figured out a way to have it on a stand for painting with the tires/rims and frame rails off.
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3133 |
Maybe try drilling and bolting channel iron to the bell housing like I did? The part you miss painting could be touched afterwards and covered by the frame rails anyway.The final drives are on jackstands now. Move them out to the hubs for paint.
55allis
I finally got a chance to work on it the other day and ended up taking a car stand and putting it under the angle iron that is under the engine on the front. I got both frame rails and the front wheels off.
As I was talking to my cousin, we got talking about getting front mud scrapers that they was a rare option from the factory? |
55allis
I found the “mud scrapers“ in a local barn.
55allis
Does anyone have a opinion about self etching primer?
I’ve never really have tried it on anything to know if it’s worth the time and money. |
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4641 |
I use self etching primer on all of mine followed by gray primer. Seals the metal to prevent rust. I have been very pleased with the results.
55allis
I might than put it on everything I sandblasted.
For a update on the tractor, I got the one tire off to get the rim welded on, I also got a picture of it down below. |
ac hunter
Orange Level Joined: 05 Jan 2011 Location: OHIO Points: 948 |
55,
Just be very careful when you are working on that tractor with the wheels off / disassembled. I always thought the ones I worked on that way were top heavy and kind of clumsy to handle. Wouldn't want a mishap. Looks like you are making good progress.
Alberta Phil
Orange Level Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3652 |
I'll second AC hunter's comment about safety. I notice you are using concrete blocks to support the tractor. And they are set in the weakest orientation to bear weight. They are a disaster waiting to happen as they can suddenly break with no warning. There have been guys badly injured or killed due to this happening. I would highly recommend that you get some solid wood blocking or heavy duty axle stands to support your tractor!! We want to be able to see the progress on this project continue!
55allis
I do have a safety stand under where the drawbar goes.
I also taped/painted up the hydraulic hoses to the snap coupler rams |
Sugarmaker
I built a frame for the back of the tractor to support it where the rock shaft attaches. I must say you need to be very careful with these perched on blocks. As others have mentioned wooden blocking is safer and steel members bolted to the tractor frame or structure are safer. We just want you around for a long time!:)
Lots of moves to make on your WD. Keep going! Here is a shot of my support system. Frame in back and steel saw horse in front. Any time your lifting any or moving it it can shift and move. Here is a shot where I was going to do the final painting so the second steel saw horse went under the rear end. the frame came off and I set the rear down on two bolts threaded into the underside. then set this down on the bolts. At this point it could still tip and get out of balance. Use caution! Regards, Chris
Edited by Sugarmaker - 13 May 2021 at 7:28am |
55allis
I got it mostly primed but now I’m stuck waiting for the humidity to go down. It has been raining about every night just enough to keep the humidity up.
Sugarmaker
Looking real good! Thanks for the update!
Regards, Chris
55allis
Today I got it painted and I love it!!!
ac hunter
Looks shiny. Bet you can't wait to get it assembled. Keep up the good work and pictures.
55allis
Got a question, where to get oil pressure gauges that are just like the original? I ordered one from tractorpartsASAP.com and it is NOT ANY WHERE CLOSE to the original.
Sugarmaker
Looking good on the paint! Yes your going to like the look! New gauges do leave something to be desired. Not sure there are any better ones?? Maybe some one knows more about these than me. Your doing good on the WD!
Regards, Chris
garden_guy
Orange Level Joined: 05 Jul 2013 Location: Illinois Points: 1118 |
Looking incredible! I got my new oil gauge from Steiner but didn't take a pic before it was installed. Will try to remember to take a pic. I did get my new temp gauge from AGCO as I felt the aftermarket ones didn't quite look right.
Edited by garden_guy - 28 May 2021 at 9:23am |
55allis
I got all brand new knobs and gauges other than that oil pressure gauge they look like original. I will try to get a picture of the tractor later.
55allis
Thanks(1)
Pictures as I promised. |
55allis
Does anyone know what this spring goes to? It fell off onto the floor when I took the frame rail off. I put a spark plug (only thing I could get my hand on at the time) beside it for sizing.
Edited by 55allis - 29 May 2021 at 7:15am |
IBWD MIke
Throttle return spring. Not sure 'return' is the exact right term. It makes the throttle stay where set.
ACinSC
Orange Level Joined: 16 Dec 2015 Location: South Carolina Points: 2561 |
Throttle compensating spring maybe ?
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8004 |
Not a return....throttle won't stay open without it. After adding D17 gov spring to 45 it needed two of those to stay at high idle.
Edited by SteveM C/IL - 29 May 2021 at 9:10am |
JTOOL
Silver Level Access Joined: 28 Feb 2021 Location: 64720 Points: 346 |
Maybe brake pedal return spring? Mine fell off when I removed the drivers side frame rail to replace the bolster on my WD45.
55allis
I got both brake return springs on and there is a hook on the throttle linkage so might go to that.
Yesterday I picked up two Allis Chalmers 6’ or 7’ snap coupler sickle mowers which looks very sad. I think I will part one out to get one going. |
ac45dave
Orange Level Access Joined: 23 May 2015 Location: SE(IN) Points: 1321 |
AC720Man
Just replaced Dads series II D15 temp gauge with an Agco gauge made in the USA. 3 times the price of the knock offs but it looks just like the original. I have heard the Heritage gauges are pretty close but I have never tried one. Do not waste your money on a knock off, you will be disappointed. Trust me, I know, I ordered one and immediately sent it back at my cost.
