Small engine won't start unless plug changed. |
BrianC
Orange Level Joined: 16 Jun 2011 Location: New York Points: 1613 |
Posted: 17 Nov 2020 at 3:50pm |
Ok the mysteries of the spark plug is bugging me. Honda GX120 on a water pump, it runs all the time (de-watering duty) Then it stops. Pull plug, yes a little oily and carboned, check gap, lay on block, hand crank, we get what looks to me like a good spark. Put it back in, NOTHING, even with ether. Replace the plug with brand new plug (same BPR6ES model plug), it starts. Run it for a few hundred hours then same cycle. With new plug it goes, old plug, nothing. So I have read that fouled plugs will fire out of engine, wont fire under compression. Is this what I am experiencing? Could the coil be weak? |
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29598 |
Likely eating just a little oil, that with the IMPROVED compounds to make gas burn get deposits on insulator of plug. Have used a Brass small gauge wire brush on plugs as this and gotten more use, in the Olden Days had a AC Spark Plug Cleaner to run them thru a few times.
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21507 |
a 'good' spark in open air should be bright blue and BIG..... any 'oily' plug is fouled... getting a few HUNDRED hours on one plug is GREAT.... if you take the 'bad' plug, clean with brake cleaner and wirewheel, does it fire ??
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77900 |
I worked at a Honda Motorcycle shop 45 years ago.. What you describe is VERY COMMON... When one "would not start", the FIRST thing we did was put in a plug.. If that didnt work then you check timing and fuel... FOUL OUT under compression was very common.... I worked on a Honda 4 cylinder car one winter.. FLOODED and COLD... no new plugs as an option.. Took them inside and BAKED in the oven at 250 degrees for 30 minutes.... and it started !!
TMiller/NC
Orange Level Access Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1774 |
Harbor freight has an air spark plug cleaner about $20, works good. Use ohm meter on "highest" setting and check for continuity between electrode and base, should not have any continuity as would indicate a short.
BrianC
Thanks, I can let this one rest. This is what the world means by "fouled spark plug". But it just seems that in the latter years, plugs and ignitions in general work better. Brigs came out with that pointless (Magnastart or such) system in the '80's and ignition problems went away for me. My personal lawn mower only gets about 30 hours per year, and I replace the plugs like every other season. But this water pump engine gets a lot of hours. Also, I was wondering if the engine could be getting tired. The Honda GX120 is an OHV with cast iron liner-about how many hours might it last in this constant load water pump duty. 1000, 2000,...?
thats kind of a loaded question... An el cheapo B&S in a push mower might get 300 hours. A mid size , base line, riding mower may get 1000 hours.. Some of better quality riders with motors that have oil filters and pressure lube are up to 2000 - 2500 hours. The highest quality industrial line motors can get 4000 hours... A lot depends on the application, how many years it is stretched out, maint , oil changes, etc... That GX120 Honda with OHV and cast liner is an above average motor... 1000 hours should be a minimum.. Dont know if i would plan on it making it to 2000.............. 1500 ?
Edited by steve(ill) - 17 Nov 2020 at 5:59pm |
Dale (Stonelick)
Bronze Level Joined: 13 Jun 2019 Location: Stonelick, Ohio Points: 157 |
I used to change the fouled plug annually in my cheap push lawn mower. Last few years I use Mechanic-In-A-Bottle (or equivalent) in each tank of gas, which keeps the plug clean.
1951 CA - 1944 C - 1949 B - Kubota M6800
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Start running a hotter plug in it. Might not cure it but it should help.
1957 WD45 dad's first AC
HD6GTOM
Wanted to clean up in the yard today, 60° today an the dang JD mower wouldn't fire a lick. Tried it 5 or 6 times. Will take the weed eater and finish it tomorrow. 1st time in 10 years it failed to run.
Walker
Orange Level Access Joined: 12 Sep 2009 Location: oh Points: 8091 |
Check to see if the magnet on the flywheel has a layer of rust on it. A piece of sandpaper will fix it.
marion
Orange Level Joined: 19 May 2010 Points: 586 |
had same problem with 24 hp honda engine, started runninng purple racing fuel with lead in it, just about cut my fuel usage in half, ran better than ever and never changed a plug again.
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2214 |
so where would you get purple racing fuel out here on the tundra??? ---- just askin----
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41214 |
try your local airport for small planes - aviation fuel runs good in many things - well as long as you don't use 115/145 Av Gas - everyone i know that tried that in their cars had problems shortly - military grade fuel with a 5 finger discount
Coke-in-MN
Champion interchange - but I would forget using a resistor plug and go with N series like N7YC
Details about NGK BPR6ES:Edited by Coke-in-MN - 20 Nov 2020 at 9:35pm |
