Waiting for Winter Diesel |
Post Reply | Page 12> |
HD6GTOM
Posted: 04 Nov 2020 at 11:10pm |
Coke #2 fuel is a heavier fuel than #1. It will jell up around 30° farenheit. #1 fuel usually does not jell up until 20 to 30° below zero farenheit. #2 fuel has more BTU of heat thus making more HP than #1 fuel. I owned a farm fuel business in the 1970-80's. I never recommend anyone use anything out of a can to lower the pore point/cloud point of diesel. Why? Because I have been out along the road all hours of the day and night changing fuel filters and adding #1 fuel to peoples fuel tanks. The old stories I always heard when I got there-- " I added the antigell to my fuel tank before I left home". I know from experience that "mouse pee" in a can does not always work. I picked up a lot of new customers because I had a couple of competitors who never blended their fuel until the 15th of November. As a result the guys had tractors gelled up attempting to feed cows grind hog feed, etc. Very seldom was there a Christmas day when I was not called out to rescue a farmer or trucker because his fuel man had not added the proper amount of #1 fuel to his storage tank.
HD6GTOM
#1 diesel is not kerosene, never has been. Kerosene is a more refined fuel than #1. Kerosene will burn cleaner than #1 diesel in your heaters.
Coke
Silver Level Joined: 30 Sep 2018 Location: MIdwest Points: 215 |
Wow, never meant to cause a furore. I got my Howes from Walmart, got my diesel in October, before they winterize it, and stuck in a cup of treatment, fired her up and let her run for a while. Also got to use my new (to me) fuel cans, now I see what everyone was complaining about with these new spouts. Can you just pull out the latch for 'em?
1957 D17 Diesel w/ M&W Pistons
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4435 |
WRONG!!! Google is right I hauled bulk petroleum for many years. As cold weather approached, when some place wanted winter blend it would start with a blend of 80% diesel and 20% kerosene. This was done while loading the trailer. The smaller precentage in the tank first, then the remainder. The same thing gets done many times for Mid Grade gasolines, unless the retail place has blender pumps. This blending was only done at a customer's request, otherwise diesel would be diesel. Some place would put a treatment into the tank first then the 7500 gallons of diesel would go in. As the weather got colder the percentage of kerosene would increase. If anyone wanted #1 diesel it would come from the loading arm for Kerosene. At many tank farms that also supplied major airports this was the Jet Fuel loading arm, Jet fuel being nothing more than highly filtered kerosene. Today's #2 ULSD is the same as #2 kerosene was 50 years ago before the EPA reduced the sulfur content. Just look at the chemical specifications. What throws a monkey wrench into the mix is the BioDiesel it completely changes the interaction of the pour point reducers to the fuel. The best thing you can do is use a quality winter treatment that you like when you purchase fuel, weather you have it delivered in bulk or get it retail. That assures you that you have winterized fuel to run in winter. The only exception would be fuel from a supplier that has a history of suppling consistent quality fuel for the weather expected.
Brian Jasper co. Ia
Google is wrong. Kerosene never has been diesel and never will be. It is more refined and lighter than #1 diesel with fewer BTUs.
Coke
I did not know that, but the Google confirms it! Kerosene is a lighter diesel oil than #2, hence why it is designated as #1 diesel. The lighter weight means it contains slightly less energy – about 135,000 BTU per gallon vs. ... Kerosene doesn't contain very high levels of aromatic compounds; they typically get concentrated in the #2 and heavier diesel fuel oils.
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 6703 |
If you torpedo heater is smoky, or leaves a haze in the air, it’s not burning clean. Use straight #1 or kerosene.
TomC
Orange Level Access Joined: 24 Nov 2017 Location: Hillsboro, MO Points: 1544 |
Number one diesel IS kerosene I believe. We used to dump 15 or 20 gallons of kerosene in each saddle tank if we couldn't get our hands on winter blend fuel. Numder one doesn't have much lubrication as numder two so I wouldn't get to carried away with the number one. That fuel is a 20 below & I absolutely have to get there fuel
TomC
If you are running straight diesel in your heater I'd say yes put some howes in there, but if your running kerosene in it I don't think it will gell up on you.
Coke
You think my diesel / kerosene torpedo heater might benefit from some Howes? I traded a guy a snow shovel for a lawn tractor for it, it's always been a bit on the smokey side.
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8035 |
45yrs ago the township would get #2 cut with #1 for grader snowplow. I think it was 50/50 but can't be sure.
Winter blend reduces fuel mileage in my semi. Part of that may be just the denser air .
TomC
Yes sir, that's the stuff,don't worry about putting to much in it won't hurt a thing, just dump it in and run it for a while to be sure it gets through the whole system, you should be good to go
Coke
I can get the Howes at my weekly Walmart shop, think I'm gonna pour a Solo cups worth in the tank add the diesel and call it done.
shameless dude
some gas stations will pour a bunch of them howes bottles down into the ground tanks and call it blended fuel.
TomC
Correct, # 1 fuel is thinner, #2 thicker so more lubrication. I have mixed #1 in with #2 or winter blend but I never did run straight #1. I froze up one time in 46 years,fueled here in Missouri, got to the old Boondock truck stop in iowa,temp dropped to something like 18 below, after that, I made a point of either getting winter blend or putting maybe 30% # 1 in.. or I'd buy a quart of howes,put half in each tank and keep trucking. Never had a problem with it again. I'm retired so no more big truck, but my tractors and my one ton get regular doses of howes. Good stuff.
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8588 |
Could be I'm wrong, but I've heard that #1 doesn't have the lubrication that #2 does. Darrel
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11420 |
About 3% less.....wouldn't think that significantly enough to be a deciding factor.
#1 has less BTU's. Less power on straight #1
Coke
Yeah, I've just been reading up on it. So #1 isn't treated, it's just a better grade of diesel with a lower gelling point and more stored energy, but it reads like it's also more volatile and a waste of money if your engine isn't pulling the extra energy from it? So winter diesel costs more? I find it hard to track fuel prices since this millenia started it just seems to go up and up and up, and then plummet, and then start over. So it's better to get the cheaper diesel and treat it, than it is to wait for winter?
Tbone95
Probably CO$T! |
Coke
I guess that answers my How careful do you have to be with mixes question, if you are pouring a whole bottle into just 110 gallons, I was thinking of adding a half cup to the tank and then drop in 10 gallons of diesel on top. Why do you avoid #1 diesel?
darrel in ND
Thanks(1)
I have not ran a drop of #1 fuel in about 3 to 4 years now in any of my diesel tractors, diesel pickup, or my semi. We have a 110 gallon service tank that we fill up at the local cenex coop, and that is what the farm tractors get filled from. And, bar none, that service tank does NOT get filled until some howes diesel conditioner goes in first, so that it gets mixed well. Half bottle in the summer time, and full bottle in the winter time. And we plan ahead, as to not fill the service tank if it is extremely cold. Most often do it if it is above freezing. I feel it mixes better at warmer temps. Haven't had a tractor gel up on that plan yet, knock on wood. And the diesel pickup and semi have to get filled in town, because we run highway fuel in them, and it's as simple as put some howes in before we start filling them, and try our best to fill em on a somewhat warm day. Would probably rather use stanadyne conditioner, but it's just not that readily available, but I guess why change something that is working. Darrel
Coke
If it treats 320 gallons, I guess it's a couple of ounces per 10 gallon of fuel, should last me a few winters. That's gonna be way cheaper than the Stanadyne stuff. Looks like they also stock a couple of the POWER SERVICE products, I'm guessing people are talking about the fuel supplement, not the cleaner. Also they have Lucas Oil treatment as well.
Edited by Coke - 22 Oct 2020 at 9:56am |
Coke
I feel like this is important for me to understand. Would you mind defining the #1 and #2? I thought it was like farm diesel vs. road diesel? Back in the UK we have diesel and pink diesel, and I think it's always cold treated.
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29696 |
I normally do the same just after beginning of November as the supplier here gets blended fuels. I use Howes currently as PS has changed formulae in the last few years and I became less enamored with it. My tank is smallish and I do not buy red fuel but road diesel due to Truck and being able to have fuel on site as needed for other duties without penalty by the Law. Has been exceptionally handy where as have eliminated the 7G will most likely move the tank to up by the house/workshop from the barn and install a pump rather than deal with Gravity as that is all too handy for the miscreants out here. So far only lost one lock and as luck would have it the tank was at last draw of a few to 20 some gallons.
klinemar
Orange Level Joined: 14 Sep 2009 Location: Michigan Points: 7935 |
I have my Diesel Fuel tank topped off every November and add the appropriate amount of Power Service to the tank. Sometimes I will add some to each machines tanks if we are going to have a cold spell. My machines are not used frequently as they were when I was milking cows. I had the 185 gel up when moving snow one cold winter. Sat in the driveway for 2 days before I could get fuel to move through it. Not fun working in sub zero weather!
shameless dude
i have everything here treated in their tanks. figgered it was nicer out to do it early than later in the cold. the "machine" tanks is even treated!
HD6GTOM
Coke, I always started blending my fuel the 1st week of October. Anything north of the Iowa Minnesota border should be running almost straight #1 fuel after Dec 1st. Truck stop/ convenience store diesel will not usually be premium #2 diesel. We have a couple of mom and pop stations here that stock straight #1 fuel. I always fill a couple of 5 gallon cans and pour it in the 200. Always leave the tank less than 1/4 tank in Oct.
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1224 |
If you are in trouble with gelled fuel add gasoline. Just don’t add too much. We helped lots of hiway guys coming from the south that got caught in our cold north.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41223 |
Hope the cold holds off somewhat longer so the blended fuel is not needed but if stocking up I would wait a bit before getting blended fuel . Truck outfit I was working for dumped a load of fuel into their tank and it was not blended right for the amount of fuel in their tank , about 50 trucks with jelled filters one cold morning 10 MPH limp to get #1 fuel to mix in truck tank and 20 MPH limp back to shop to get filters changed
