Running/Marker Light ? |
FREEDGUY
Posted: 16 Oct 2020 at 6:21pm |
Where are the "upper" marker lights supposed to be located on a P/U? I thought it was 5 lights on the leading edge of the cab, but Ford has 3 mounted on the upper grill of their "odd looking" Raptor that I've been seeing more and more of recently.
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29227 |
Should be highest facing edge of the factory built cab, Added bodies as sleepers and campers have their own. Raptor Lamps NOT for Marker just architectural enhancements.
Edited by DMiller - 16 Oct 2020 at 6:51pm |
Lars(wi)
Orange Level Access Joined: 14 Sep 2009 Location: Permian Basin Points: 6530 |
Not sure if cab marker lights are mandatory on pick ups?
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4383 |
Marker lights are required on vehicles 90" or wider. Those Frog trucks can do what ever they like. Oooooh Shiny The factories have gone to adding glitz and gimmicks to run the price up. 50 years ago you could get a fully outfitted 3/4 to that could actually last a few years and WORK for about $4,000 or less. Nowadays these things are full of plastic and computer controlled crap that is bound to break down before you can pay them off.
Edited by PaulB - 18 Oct 2020 at 4:32pm |
FREEDGUY
That's the problem, Ford put the yellow lights on the grill, why would they do that ?? I thought I was meeting a "tri-cycle" the other morning in the dark
Lars(wi)
Was it a factory option, or something the owner did as a DIY?
FREEDGUY
I've seen several Raptors (becoming more and more of them) with the same "marker lights" on the top of the grill.
They are not "Marker Lamps" They are Ford Dress out accessories. Marker lamps go ON THE CAB.
FREEDGUY
Why are they YELLOW??? To me that's a MARKER LIGHT ??!!
If they aren't "marker" lights, they should be PINK !!!! Edited by FREEDGUY - 17 Oct 2020 at 6:12pm |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77210 |
Most aftermarket grills for trucks and now putting 3-4 little yellow LED lights on the top edge below the hood.... Like DAVE said, its window dressing.. No value at all.
FREEDGUY
It's not the "value" issue, it's legality of where/how many of them(lights) there are on this Jeep/Hummer abomination of a "truck". I can't say for sure if they were A/M grills or not though
FREEDGUY
Is this considered "after market" ?? Yes ,that's the configuration that approached me
There are a zillion of them on e-bay for sale for $200. You can get them for ANY manufacturer of Truck... Lots of guy buy them to replace the factory CHROME grill to make a BLACK OUT..... for looks .... like the RAPTOR.
shameless dude
pink? someone say pink???
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21317 |
any colour as long as they're not flashing red/blue.......... ..though they do look silly,serve NO purpose, cept send money to China. that being said, DRL ( Daytime running Lights) , are NOT legally required up here in Canada..somehting that was PROVEN to have saved lives...sigh... Jay
TomC
Orange Level Access Joined: 24 Nov 2017 Location: Hillsboro, MO Points: 1544 |
Yes they did,, I just figured someone's slip was showing.
Nothing illegal of Amber Accessory lamps to front or Reds to Rear, Nobody cares as stated Unless Flash as Emergency Vehicle Lamps. Can add a Hundred lamps to a machine and DOT does NOT G.A.S. unless are not working.
Most of these lamps are NOT Required and yet if NOT Working can be fined for as Inoperable lighting.
No reason but bragging rights for this
FREEDGUY
DMiller, I can appreciate ALL of the lights and "bling" on a big rig , but even in your pics, there's not ONE amber light on the middle of the grill ?? They are all "high and wide" other than the under front bumper lights .
See them In grills, around grills across grills. They mean NOTHING, just Bling. What do you not get of that, is Just a Accessory Lamp.
ONLY required are IF NEEDED by Truck Category, two front and two rear Corner Markers and Five Cab &/or Box Markers, TWO Tail Lamps TWO Stop/TS Lamps Two Front TS Lamps and by year a Alternate THIRD Or Upper BRAKE Lamp. PERIOD, GRILL Lamps are BS Bling. READ: Edited by DMiller - 18 Oct 2020 at 3:59pm |
I have seen the light show setup as a CROSS or FACE in the center of the grill also.. Its all SHOW... SO WHAT ?
Or like this:
Means NADA
Edited by DMiller - 18 Oct 2020 at 4:02pm |
THIS is the CFR(Code of Federal Regulations) for TRUCK Lighting, Raptors are LARGE Toys and oversize Cars.
Edited by DMiller - 18 Oct 2020 at 4:06pm |
TomC
I had mine pretty well lite up,nothing like that but enough to where I had myself convinced it would give the OTHER 75% something to see and guide them when they tried backing in next to me.
FREEDGUY
Your "CROSS" or "FACE" is pretty much a solid row of lights, the 3 "individual" lights on the raptor are deceiving IMO is all .
PaulB
in many sates anything other than clear or amber facing forward and red or amber facing rear (except for clear lights when in reverse gear) is ILLEGAL!!! It's right there in the vehicle law book published by the states MVA. Although for Barney Fife to do anything about is is another problem
