Leaking Sediment Bowl |
MotorCityBear
Bronze Level Joined: 27 Jul 2013 Location: N. E. Georgia Points: 84 |
Posted: 16 Sep 2020 at 5:02pm |
So my 1953 B sediment bowl always leaks between the top edge of the glass bowl and the underside of the mount. I replaced the gasket but it still leaks. Any ideas on how to stop the leaking?
Rob
1953 AC B Kubota L3901 Blairsville, GA |
Kevingweq
Bronze Level Joined: 03 Sep 2019 Location: Massachusetts Points: 37 |
Had similar problem on an IH dozer , Ended up making a gasket out of a piece of silicone rubber sheet ,Been leak free for 5-6 years
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50578 |
Drain, remove sed bowl, check the gasket surface for flatness. Sometimes someone overtorques the bail nut, and bends the pot metal of the gasket surface. Also check the bail nut and stud, to see that they aren't stripped. Check the bail clip, itself for bends. If you have any questions at all, a whole new sediment bowl is under $30 at steiners, maybe less than that, if you shop around...
I cut my own gaskets, I use the thicker cork rubber, about 1/8", seems to last longer, for the same effort...
Dusty MI
I've found that if I twist the bowl while tightening it, it seems seat and seal better.
MotorCityBear
Thanks for the replies. I will try your suggestions.
Rob
FREEDGUY
It's been "my" experience that the tighter you turn the bowl nut, the harder it leaks .
NomoreJohnDeere
Silver Level Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
Yes on all the cork
don't be afraid to soak the cork or grease a little you can tighten a bit more into the cork |
HD3
HudCo
Orange Level Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3296 |
the housing is not clean enought were the gasket seals
dawntreader74
Orange Level Joined: 28 Oct 2013 Location: Manteno Points: 1758 |
rubber O ring' works the best. try it'
shameless dude
i did the same as Kevin and Dawnt. on alot of my units. seems cork never resealed after removing the bowl a few times to empty and clean it.
BKarpel
Bronze Level Joined: 27 Apr 2012 Location: Collinsville IL Points: 108 |
On my 210 I found out there are 2 different part numbers depending on the glass bowl size (tall, short). I tried one from rural king and carquest they leaked. Got seal from dealer and been fine.
