190xt pto removal |
2wise4agm
Orange Level Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
Posted: 20 Jul 2020 at 12:50pm |
What is needed to remove the PTO completely from a 190xt? Looking to save a lil weight. I can make a plate to go in place of it, and a plug on the output, but is there a seal between the torque tube and transmission that would require me splitting the tractor to plug? |
tbran
Orange Level Joined: 14 Sep 2009 Location: Paris Tn Points: 3213 |
for 25# ? yes , there is a double seal in the belly - you will join the sumps.. Not worth it unless you split it and remove all the pto gears and shafts/shifters and plug the holes; add something to limit hydraulic oil used while at it.
Edited by tbran - 20 Jul 2020 at 10:04pm |
Orange Level Access Joined: 12 Sep 2009 Points: 19362 |
If you are removing the lift arm housing and the PTO shaft, there's some weight loss to be had there. You should plug the hole where the PTO shaft went thru at the front to keep hydraulic oil where it belongs and to raise transmission oil level to flood the differential gears. Doesn't require a split, just have to be a little creative.
bradley6874
I used the rubber expandabe plug from an oil fill cap for a big truck
By golly, that sounds like a pretty good idea !! Reach in from the right side and install it in the hole ??
tbran
When we replaced the PD with a coupler many yrs ago seems like the screw swedge type oil filler plug for the xt's were the same size ???
