AC 540 wheel loader
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Topic: AC 540 wheel loader
    Posted: 14 Jul 2020 at 11:44am
I am looking for a hydraulic pump for an AC 540 wheel loader. AC part number is     1012212.   I have several leads but  nothing firm as of yet.
Curt Anderson
HD3, HD5B, HD6E, HD6AG,HD6B dozer, I-400, 615, 616,(2) 620, 720, ACP25 lift truck, 1956 D Special Grader, AC 540 loader, AC 655 crawler loader, AC #84 plow, Simplicity lawn tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 3:15pm
Which pump, Main hydraulics or trans?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 5:36pm
The pump supplies the steering and loader.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 6:59pm
This is the outermost of the three stack or by itself?  I looked at Minnpar page 113, appears to be Eaton Cessna similar to the Hyd pump I have had issues locating.  On an ear of the two bolt flange head will be a Eaton/Cessna P/N, load that as a Google Search will have better luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 8:11pm
This is the front or outermost pump. Will only put out 1000 psi.
Curt Anderson
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 11:09am
Check for the stamping numbers, if there will be Eaton Cessna and a Hydraulics shop can find it.
