WD engine heater |
MNfarmer
Bronze Level Joined: 15 Jan 2010 Points: 6 |
Posted: 08 Jul 2020 at 4:53pm |
Is it possible to plumb a tank heater into a WD?
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50549 |
In a word, Yes...
MNfarmer
Where is the correct place to plumb it? I went from the block drain to the water pump and it won't circulate.
Boss Man
Orange Level Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 608 |
Been a long time, but if memory serves I went from the block drain to the thermostat housing. Dont remember if there was a plug or I drilled and tapped.
Gatz in NE
Orange Level Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1033 |
tank installed vertically ? if it's laying down it probably won't circulate correctly |
MNfarmer
It's at about a 45 degree angle.
dr p
Orange Level Joined: 24 Feb 2019 Location: new york Points: 1013 |
Goes from the bottom of the block to the thermostat housing on the near side of the thermostat. I used two short of rubber hose and a small piece of metal to get the block heater completely vertical. Ironic question for a 90 degree day
You are risking burning up the element, that way. Proper way is to have it in a vertical line.
MNfarmer
I always do have them vertical, but mine doesn't have an outlet on the thermostat housing. Thanks everyone for the info!
ac fleet
Orange Level Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2210 |
One of mine has one on it---dont think it works, but its hanging on there.
