Lawn mower |
Dave Wisc.
Orange Level Joined: 12 Jun 2015 Location: Wisc. Points: 216 |
Posted: 29 Mar 2020 at 1:54pm |
My daughter is looking at getting a different used lawn mower. Yard is not real steep so what is your idea. Don’t want something that will give her a lot of problems either as I am the fix it man.
Gary
Orange Level Access Joined: 13 Sep 2009 Location: Peterborough,On Points: 5173 |
Lets narrow it down. Does she need a 'walk behind', a self propelled 'walk behind', a riding lawn mower, a Garden Tractor capable of other attachments, or maybe even a 'zero turn' ? |
Dave Wisc.
Ok need a rider looking at what brand do you guys like or have confidence in maybe zero turn too
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 21505 |
Ok I'll start the 'ford vs chvy' debate.... I've had GREAT luck with all brands that are really MTD 'under to hood'. Since you're looking at used, I'll assume a $500 limit ? That should get you a hydrostatic drive, 42" deck, 5-10 years old. Cub Cadets (aka MTD) should have greasable spindles and pretty tight turning other are sealed, if decks noisey(grindy) , new bearing needed, $20/pair. The things to look for are...oily engines and decks rotting from never cleaning the grass out. B&S engines tend to separate at the crankcase halves. PITA to tighten as engine has to come out. Some Kohler have HUGE issue, same bolts back off, engine handgrenade. All riders in the 15-25hp/ 42-54"deck will do say ,up to 2-3 acres. Check tires, side cracks = time for tubes, fronts are 'fun' to do.....
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11558 |
Well, if she doesn't want to spend to much money, I see (around this neck of the woods anyway) a lot of those Green Craftsman riders. They seem to last a long time, and I believe some have Kohlers in em' for power, and some B/S. As for a ZT, she'll need a lot more money to purchase a used one of those. And with those, you want to check how many hours it has on it. If she doesn't have a lot of property, a small rider with a good deck would probably serve her fine... HTH
Steve@B&B
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3894 |
Ive bought a couple older JD garden tractors cheep a 216 for $200 a 214 with snowblower for 400. and of the MTDs can be had cheep. check the decks for rust out. if thev have been kept fairly clean they be good. the engines usually outlast the decks be a long time if they have been kept in oil. most often a oil change spark plug and belts will bring them back to lasting a long time. if its been left out in the yard to rust away and never had oil put in it its junk. you can tell with just a walk by inspection if its worth looking at. I had a MTD that I mowed 3 acres with for many years. it was a riding mower. cleaned the deck before winter storage and changed the oil every 5 years or so. after 15 years I put new tires and belts on and gave to my brother its still mowing grass 10 years later. I personaly like my old John Deere's they are very heavy built and the local JD dealer has parts. I do have a simplicity (they made the allis chalmers garden tractors) its a better tractor but parts are hard to come by.
ACmowerguy
Orange Level Joined: 20 Apr 2010 Location: Winfield, MO Points: 1199 |
JD will generally give you the best parts support of any brand. Anything cheap and old is probably going to regularly need some repairs. I have had lots of Simplicity's here and some were better than others, but also some JD's. Foot pedal drive is nice to have. Smaller units with hydrostats and high hours may have transmission problems down the line though I have seen them last to varying degrees.
Orangeisgreat190
Bronze Level Joined: 07 Apr 2020 Location: Ohio Points: 50 |
I have two suggestions. First I will say the Simplicity Sovereign (also called Allis-Chalmers 900 series, older ones were simplicity 7100 series). They are built very tough and durable. They made these for many years so parts are plentiful. If well taken care of, they will give many years of trouble free service. I used to help take care of a 15 acre cemetery using only Simplicity Sovereign and AC 900 series. For the price, they could not be outdone by any other mower. The cemetery was rough and hard on equipment. They held up great. My Dad has a 914 Allis with over 4000 hours of mowing time.
I also have had great luck with Wheel Horse. They are a very simple machine to work on and maintain. Toro supplies parts and the models from about 1990 and newer were called Toro Wheel Horse. They used the same basic drive train for many years and parts are relatively easy to find. Once again, very heavy built and user friendly machines.
Mike K
Silver Level Joined: 27 Sep 2009 Location: Edgar, WI Points: 216 |
If you are looking for Allis Chalmers mower. I have a great assortment. Sprint to 5015 diesel. call 7155817330
cottngton
Bronze Level Joined: 23 Sep 2020 Location: Washington Seat Points: 5 |
I would advise you to try solar-powered mowers. It's more ecological for the environment. Also, you will save some money for the gas you don't use. I think that we should start thinking of the environment a little. With such small steps, we will increase the lifetime of nature. For example, I started to use a cordless weed eater. It was a very delicate question, but I found out the necessary information on how to choose a weed trimmer. I am very glad that I can charge it after the use. It's very easy to handle and to use, and it's eco-friendly.
Edited by cottngton - 15 Mar 2021 at 3:45pm |
EvanColeman2001
Bronze Level Joined: 18 Dec 2020 Location: Vermont Points: 15 |
this hurt the soul to read
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4641 |
Geez, takes fuel of some sort to make electricity, except a power dam I guess. Solar powered? Mow 10 feet and run out of power. Take ya 10 days to mow your yard. Yeah, I agree, painful to read
Edited by AC720Man - 14 Mar 2021 at 8:51pm |
EvanColeman2001
Concerned about the environment? realize that to make all these batteries you need to extract rare earth minerals, carbon emitting equipment is used to get it in the first place, then to process it into a useable product, the material is sent to a factory that has electricity made from a power plant fueled by coal. the means to obtain and create a "sustainable" power source just doesn't exist. I am not saying that it's not another way to go about mowing the lawn; but it certainly is not as sustainable as people make it seem. as soon as we have like 80 more years of mass produced batteries will we know the real effect. Hydrogen engines are the real way of the future if you ask me... so run your gas weed whacker and sleep peacefully knowing you'll be peacefully 6 feet deep long before it makes any difference
In my neck of the woods, if I had too much grass to cut, I'd fence and get a few sheep or goats. They not only automatically trim the lawn, they're EASILY sold at the end of the year..so someone else is PAYING me to cut my lawn ! Ther's a HUGE demand for goat here...
Dusty MI
Many years ago there was a big worry about the hole in the ozone layer. Then I learned that one volcano caused more damage than everything that man had done.
